Gentoo for pine64 - longsleep kernel
I based this image of xailus Gentoo image, found here https://forum.pine64.org/showthread.php?...ght=gentoo
I used this upgrade procedure found here on server_fault, (answer with 5 upvotes)
It uses the new Gentoo 17.0 profile
~arm64
gcc version
[1] aarch64-unknown-linux-gnu-7.2.0 *
binutils version
[1] aarch64-unknown-linux-gnu-2.29.1 *
glibc version
ldd (Gentoo 2.26-r3 p4) 2.26
As this uses the experimental branch it's advised to keep this system up to date.
Regular
Quote:emerge --sync
emerge -uDU --keep-going --with-bdeps=y @world
To download this image
Quote:git clone git://git.code.sf.net/p/pine64gentoo/code pine64gentoo-code
It's sized for a 32gb sd card and LZMA compressed.
Next job is for the installing the mainline kernel which is being tested.
Happy compiling!
  Programming languages support under PINE64 baryluk 6 20,499 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,590 11-13-2019, 09:41 AM
Last Post: roel
  Manjaro arm on pine64+ roel 2 10,531 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 38,672 03-22-2019, 09:25 AM
Last Post: llungster
  Gentoo Linux test image xalius 23 72,468 01-28-2019, 11:05 PM
Last Post: necrose99
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 6,585 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 10,003 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 56,459 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,898 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,353 09-25-2018, 03:39 PM
Last Post: bjbb17
