How to boot alternative kernel image with u-boot?
I'm currently using longsleep's u-boot and kernel image, which work great.
I'm also trying to build some experimental kernel images, however it doesn't always work.
It's quite a troublesome process to remove the sd card, mount on another machine, recover kernel image, put the sd card back, and boot again.
Is it possible to select alternative kernel image from u-boot without remove the sd card?
See http://linux-sunxi.org/FEL/USBBoot
(06-26-2016, 01:58 PM)longsleep Wrote: See http://linux-sunxi.org/FEL/USBBoot
Fantastic! Thank you so much!
But this does not work with boot0 well, right? First we need to get the SPL support for Allwinner A64 in U-Boot.
  PineA64+: Audio in 5.0 Kernel puzzles 6 16,212 11-13-2019, 09:41 AM
Last Post: roel
  Pine Board using linux stuck during boot sequence ktaragorn 4 14,412 03-30-2019, 06:48 AM
Last Post: ktaragorn
  Gentoo Linux test image xalius 23 71,079 01-28-2019, 11:05 PM
Last Post: necrose99
  Rockpro64 NFS root mount (kernel 4.20) - ethernet help? tenspd137 0 4,832 12-06-2018, 01:14 AM
Last Post: tenspd137
  NVMe and new kernel bjbb17 0 4,289 09-25-2018, 03:39 PM
Last Post: bjbb17
  Real-time linux kernel Artyom 45 120,646 09-11-2018, 01:08 AM
Last Post: zzwpine
  DKMS on kernel 3.10.107-pine64 obrienmd 5 14,157 06-21-2018, 05:45 PM
Last Post: evilbunny
  Secure boot & OTP efuse program devangpanchal90 0 4,097 05-25-2018, 01:59 AM
Last Post: devangpanchal90
  Kernel for A64 git longsleep 179 427,241 03-25-2018, 03:25 PM
Last Post: Luke
  boot process for pine a64 awaysu 1 6,552 01-24-2018, 05:09 AM
Last Post: xalius
