Remote Desktop Support?
Is there any build that supports a remote desktop app, like VNC?
I need to connect to the Pine from Windows 10 machines.
Installed the "Ubuntu Linux Image base on Longsleep 20160421 image" from the Pine 64 Wiki page. From a terminal prompt I used apt-get install xrdp and then with MobaXterm I was able to connect to the desktop without any issues. Very snappy! MobaXterm is great but not sure if it works on Windows 10. I am running Windows 7 to connect.
(04-30-2016, 09:49 PM)Rochambeaux Wrote: Is there any build that supports a remote desktop app, like VNC?.
If you use the linux builds frpm longsleep (see Software - Linux development), you can install any GUI you like on top and of course use it via VNC or remote desktop from Win10. Thats my setup at the moment to run the Pine headless and use ssh or rdestop to access...
Works fine for me.
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
I'm not a LINUX guru by any stretch.. Is there a step by step process on how to do this?
I did an extensive Google search but the walkthroughs I found wouldn't work with the Pine builds.
Is there a simple "click and install" GUI based one?
Rochambeaux what distro are you currently using?
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
xubuntu-xenial-20160421-longsleep-pine64-8GB
I didn't try using VNC, but check out packages like: vino, xrdp, vnc4server, linuxvnc, x11vnc, tightvncserver. If you can log into , into Mate and install vino, that would be probably fastest way to run vnc server.
(05-01-2016, 10:25 AM)baryluk Wrote: I didn't try using VNC, but check out packages like: vino, xrdp, vnc4server, linuxvnc, x11vnc, tightvncserver. If you can log into , into Mate and install vino, that would be probably fastest way to run vnc server.
Is there a better option?
I'd like to use Splashtop or similar but don't think there's an ARM build.
I do not know what splashtop is. Never tried it. I cannot find it in Debian unstable. Try grabbing the sources from the official page, and compiling it yourself. It might just work.
(05-01-2016, 11:07 AM)baryluk Wrote: I do not know what splashtop is. Never tried it. I cannot find it in Debian unstable. Try grabbing the sources from the official page, and compiling it yourself. It might just work.
Yeah . you just went way over my ability level...
LINUX has had a GUI for how many years, decades? There should be a GUI remote desktop solution somewhere.
  Programming languages support under PINE64 baryluk 6 20,752 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  AXP803 Battery Charger Support xalius 14 40,017 12-22-2017, 08:59 AM
Last Post: Velociraptor
  Found this fully working RASPBIAN Image that boots to desktop speedro86 21 45,409 10-07-2017, 10:06 PM
Last Post: speedro86
Wink Pine64 Will support Freenas or openmediavault ? joe 1 7,329 04-13-2017, 07:44 AM
Last Post: xalius
  Possible to get 4K resolution on Linux desktop? tycoonbob 6 17,625 01-12-2017, 01:28 AM
Last Post: swinging
  Pine64 as a viable desktop replacement ? here are my thoughts! Luke 11 27,471 01-06-2017, 04:49 AM
Last Post: dkryder
  Problems with remote printers with pine64 (SOLVED) LocoMJ 2 7,089 12-14-2016, 04:32 PM
Last Post: LocoMJ
  Binfmt_misc support cztian 1 5,805 08-17-2016, 11:49 PM
Last Post: longsleep
Question Joystick/Gamepad support Drakuwa 3 9,867 08-10-2016, 10:12 AM
Last Post: xalius
Big Grin Funny ! Support Intel x86 linux applications on ARM-based ( PINE64 ) not freeware joe 10 25,348 08-09-2016, 05:59 PM
Last Post: dkryder
