PineTab2 virtual keyboard: symbols instead of numbers
Hello! I'm having a bug with the PineTab2 virtual keyboard (Maliit) with two different Flathub packages (ungoogled-chromium and Xlog).
When I press a number with the virtual keyboard, the "shift" version of that number is actually entered into the UI. For example, when pressing 3, # is entered, or 4, $ is entered, etc.
I've left the state of the PineTab2 largely unchanged since receiving it — no major OS changes, etc.
Is anyone else able to reproduce this? If yes, where's the correct place to report this bug? Thanks!
I have the same problem with the vitual keyboard
(06-14-2023, 07:14 AM)clemfandango Wrote: Hello! I'm having a bug with the PineTab2 virtual keyboard (Maliit) with two different Flathub packages (ungoogled-chromium and Xlog).
I have the same for Firefox. Installed with pacman, not flatpak. Also I am using Plasma Mobile, not sure if that is relevant.
I have the suspicion now that it might be that the affected apps run X11 instead of Wayland?
i have set one parameter to start Firefox in Wayland mode and the keyboard issue as well some other niggles disappeared. Still no idea how to fix the other apps, but it might be worth investigating.
Great information, switched chromium and Firefox to Wayland mode and and it worked like a charm
I am using Brave browser; Wayland flag worked great for a while. Problem seems to be back with Brave v1.52.130.
Suggestions?
  New PineTab2 dRateNWAytORy 0 26 Yesterday, 04:31 PM
Last Post: dRateNWAytORy
  Someone is interested for a PineTab2 8GB in Mexico? genobraker 0 234 03-06-2024, 07:22 PM
Last Post: genobraker
  Bricked my PineTab2 using Jumpdrive? jkboyd 2 403 02-24-2024, 07:14 PM
Last Post: jkboyd
  Castle Game Engine on PineTab2 now officially available michalis 1 879 12-14-2023, 12:22 AM
  PinePhone or PineBook USB-C hubs on Pinetab2? Evergreen 1 748 11-05-2023, 10:20 AM
Last Post: WEF
  Pinetab2 screen issue. screen does not power on at all bluemage 5 1,441 09-25-2023, 08:29 PM
Last Post: bluemage
  Some keyboard keys type two lettters lee19gs 2 795 09-21-2023, 09:56 AM
Last Post: dachalife
  What's the MAX RAM you can install to PineTab2? Ptab2newb 2 1,019 09-12-2023, 12:38 PM
Last Post: Ptab2newb
  Booting from SD card on Pinetab2 samochimaaron 10 3,152 08-23-2023, 09:38 AM
Last Post: diederik
  Pinetab2 without Wifi a comfort extra? Schlucker 8 3,241 07-14-2023, 03:09 AM
Last Post: gregb49
