Another stuck watch!
Sounds as if the watch already is paired in the Android bluetooth settings itself. You could try to see if it's there and if so delete it.
From a home screen, navigate to Settings-->Connections-->Bluetooth
If any "Pinetime" or "Infinitime" devices are connected, tap the appropriate device name or the Settings icon (right)
Tap 'Forget' or 'Unpair'.
Open GadgetBridge and try scanning for the device.
Good luck!
Gary
(06-07-2023, 07:23 AM)GaryM Wrote: Sounds as if the watch already is paired in the Android bluetooth settings itself. You could try to see if it's there and if so delete it.
Good luck!
Gary
THAT WORKED!!!
Ha, amazing. So simple, I never thought to look in Android's bluetooth connections and remove it from there Smile
Many thanks for staying with me and helping out!
  Stuck in OTA update mode mark1250 4 4,184 06-01-2023, 10:06 AM
Last Post: feketej
  Update of new watch consistently fails bitreaper 5 5,000 06-01-2023, 02:29 AM
Last Post: feketej
Exclamation Stuck at Infinitime Logo with 18% battery on full charge? PiningFjord 1 1,197 03-13-2023, 05:05 PM
Last Post: PiningFjord
Question Green skin-facing LED stuck on aereaux 0 818 03-05-2023, 02:02 PM
Last Post: aereaux
  Pinetime stuck at infinitime logo monto 3 2,950 08-27-2022, 11:26 AM
Last Post: monto
  Whoops! Developing games on this (apparently not Linux) watch. Www 2 2,256 06-26-2022, 07:12 AM
Last Post: Www
Question Open box, upgrade, dead watch? ahaplesshappenstance 5 2,914 06-25-2022, 03:13 PM
Last Post: ahaplesshappenstance
Question Stuck in bootloader MLG_Herobrine 2 1,951 06-06-2022, 04:04 PM
Last Post: MLG_Herobrine
Question What can/can't I do with a PineTime smart watch (sealed)? danimations 7 6,062 04-16-2022, 07:18 AM
Last Post: _slowmanship_
  Another similar smart watch VMMainFrame 3 5,645 09-16-2020, 02:33 AM
Last Post: danielo515
