Pinetime stuck at infinitime logo
Hi all,
my brand new pinetime is stuck at the "infinitime logo" after 2-3 days.
I've used gadgetbrige to flash the 1.9.0 firmware as soon as the watch arrived. Everything was fine for about 2 days. After that the "inititime" logo appeared and i got stuck there. I've discharged the watch, read some help request so i went in the blue recovery and then in the red one and got it flashed again. Seemed fine for about a day and then "infinitime logo" again.
Tried to flash it again with 1.9.0 or anything but nothing worked. Rebooted phone, tried gadgetbrige, nrf connect, different boot (green, blue and red) but i can't associate the watch with gadgetbrige anymore (no entry there so no flash) and with nrf connect i get a "starting DFU, disconnecting" with nothing done apparently (uploading the firmware usually require about a minute).
Any idea on how i can recover from here?
Thanks!
small update, tried yesterday. If i leave the watch in charge or discharging, everything is fine. If i start any kind of dfu update via bt the watch reboots. it doesn't make any difference if i do that on green, blue or red startup. anyone has an idea on how to get the watch back?
Same here !
Recovered!!!!!
Following the thread here
https://forum.pine64.org/showthread.php?tid=17121
I've downloaded a previous version of nrf connect from here
https://github.com/NordicSemiconductor/A...4.22.3.apk
Then I've flashed successfully
pinetime-mcuboot-recovery-loader-dfu-0.14.1.zip
(I don't know if it's relevant, i don't think so)
After all I've flashed infinitime 1.8.0 and seems to work.
Finger crossed....
  PineTime at FOSDEM jmlich 5 795 02-07-2024, 11:48 PM
  PineTime turns off when removed from cradle tynstar 0 248 01-31-2024, 11:57 AM
Last Post: tynstar
  PineTime and Amazfish on Ubuntu Touch jmlich 1 752 10-14-2023, 04:12 PM
  PineTime is dead!! Markdanni123 12 13,864 09-18-2023, 10:17 PM
Last Post: ccchan234
  PineTime Sleep Tracking any_mouse 12 12,371 07-10-2023, 05:41 PM
Last Post: davidair
  Another stuck watch! Ralpharama 11 2,964 06-07-2023, 09:10 AM
Last Post: Ralpharama
  Stuck in OTA update mode mark1250 4 4,122 06-01-2023, 10:06 AM
Last Post: feketej
Exclamation Stuck at Infinitime Logo with 18% battery on full charge? PiningFjord 1 1,161 03-13-2023, 05:05 PM
Last Post: PiningFjord
  PineTime Dead out of box? henkery 1 1,235 03-12-2023, 04:34 PM
Last Post: henkery
Question Green skin-facing LED stuck on aereaux 0 798 03-05-2023, 02:02 PM
Last Post: aereaux
