Stuck at Infinitime Logo with 18% battery on full charge?
Exclamation
Hi! Long time PineTime user since 2020, and I've run into a problem that I haven't seen before.
I left my watch to charge in its cradle last night, and I put it on this morning with a full charge. Then I put the watch in my pocket to wash a few things. When I took it back out I noticed it was now on the Infinitime screen with the two triangles, I thought maybe it got bumped somehow and tried holding it down to reset it, still boots to the Infinitime screen. I also tried booting into blue and red modes, and it's still stuck on the same screen. I've tried flashing the firmware using NRFConnect and Gadgetbridge, but even though the device is connected to the phone over bluetooth it will disconnect when trying to update or downgrade the firmware. What's really strange is the PineTime is showing a battery percentage of 18% consistently, when I know it was at 100% before taking it off. Huh The battery should be ok, I've used it for a week before having to recharge it.
Any help or suggestions would be appreciated. Other than this issue the watch has been very reliable. I'm currently running 1.11 "Red Nectarine".
(03-13-2023, 03:25 PM)PiningFjord Wrote: Hi! Long time PineTime user since 2020, and I've run into a problem that I haven't seen before.
Just a quick update:
I fixed it by doing the following:
Removed bluetooth connections between NRFConnect and GadgetBridge
Restarted both the phone and the watch
Reinstalled the firmware after pairing back up with GadgetBridge
Firmware installed and I have a watch again!
  Another stuck watch! Ralpharama 11 3,061 06-07-2023, 09:10 AM
Last Post: Ralpharama
  Stuck in OTA update mode mark1250 4 4,187 06-01-2023, 10:06 AM
Last Post: feketej
Question Green skin-facing LED stuck on aereaux 0 821 03-05-2023, 02:02 PM
Last Post: aereaux
  Pinetime almost dead... only shows Infinitime logo. lightweight 8 6,938 02-11-2023, 09:30 AM
Last Post: alexmitroff
  Pinetime stuck at infinitime logo monto 3 2,950 08-27-2022, 11:26 AM
Last Post: monto
Question Stuck in bootloader MLG_Herobrine 2 1,952 06-06-2022, 04:04 PM
Last Post: MLG_Herobrine
Question Does anyone know what's coming in Infinitime 1.9.0? danimations 3 2,495 04-09-2022, 07:45 AM
Last Post: danimations
  Bluetooth pairing issues (Mobian, InfiniTime) johns 1 2,245 02-22-2022, 08:01 PM
Last Post: Arsen6331
Question Battery indicator calibration sal 0 1,029 02-06-2022, 08:51 AM
Last Post: sal
  BT toggle/battery life ronaldheld 0 972 02-04-2022, 04:46 AM
Last Post: ronaldheld
