When does Pinebook Pro power LED go on?
I inherited a broken pinebook pro with this backstory:
I fired up my Pinebook Pro after having it on the shelf for 2 years. It won’t boot (infinite load graphic), so I tried to reinstall Manjaro Linux on it.  The microsd was very janky.  I opened it up to toggle the emmc switch so it would boot and now it won’t turn on.
The manual has an entry on this troubleshooting, and mentions pressing RESET which did not help.
There is nothing when power on. All LEDs are off, except the charge port LED.
What I tried:
* reset button
* re-enabling eMMC: device turns on, but stuck in infinite boot spinner. Alt-F2 shows empty text screen.
* disconnecting battery, using bypass cable.
* measured barrelplug voltage at 5.4V
Which takes me to my question:
Is the power LED supposed to light up when the device is switched on, with eMMC disabled? Or does the software on the SD card actually have to do this? So far, I tried to turn it on with no SD card seated.
Ok, this should be in the manual:
The LED is not a power LED, it is a status LED set by either bootloader or OS.
If there is no SD card present, and no eMMC, then powering on the device will show nothing.
  Pinebook Pro Initial Impressions kunger 443 589,213 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,299 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 401 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 304 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 293 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 227 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 678 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 741 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,624 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,242 12-15-2023, 02:11 PM
