new Pinebook Pro making occasional noises
Dear all,
I've gotten my hands on a new Pinebook Pro with the pre-installed Manjaro ARM recently. I've been working on it for a few days now and it suits my needs very well.
However, occasionally (I haven't managed to figure out a pattern yet), the laptop starts making weird noises: either a fairly loud "knack" (as if someone closed the lid with force) or a longer higher pitched tone which ends with a "knack". Then I can go on working on the machine for e.g. 20 minutes without any issues until all of a sudden it again makes one of the noises described above.
1. Is/has anyone encountering/encountered the same phenomenon? If this is a known issue, is there a fix for that?
2. Is this software or hardware related? What information do you need from me to evaluate that/narrow down the problem?
In the end I need to know, whether I can fix this myself or whether I need to file a warranty case with PINE.
Thanks in advance for your help!
You can try this: https://forum.pine64.org/showthread.php?...#pid113331
Or play an inaudible sound. https://www.reddit.com/r/PINE64official/...d_its_not/
I'm guessing it will impact battery life, but I don't think it will be much.
(12-26-2022, 03:27 PM)LivingLinux Wrote: You can try this: https://forum.pine64.org/showthread.php?...#pid113331
Thanks for pointing me to that thread & particular post.
I did not try the wireplumber hack but settled with changing the audio output to headphones. That solves the issue for my use cases.
Thanks for your help!
  Pinebook Pro Initial Impressions kunger 443 588,216 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,289 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 395 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 297 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 287 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 222 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 671 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 735 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,608 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,224 12-15-2023, 02:11 PM
