apt-get update "The following signatures were invalid..."
From the terminal
"The following signatures were invalid: EXPKEYSIG 951D61F2BC232697 Mobian Project <admin@mobian-project.org>
Reading package lists... Done
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://repo.mobian-project.org bookworm InRelease: The following signatures were invalid: EXPKEYSIG 951D61F2BC232697 Mobian Project <admin@mobian-project.org>
W: Failed to fetch http://repo.mobian-project.org/dists/bookworm/InRelease  The following signatures were invalid: EXPKEYSIG 951D61F2BC232697 Mobian Project <admin@mobian-project.org>
W: Some index files failed to download. They have been ignored, or old ones used instead."
I remember having similar problems with other repos but cannot find the fix. Where can I find the new key?
According to the chats, the easiest way is
curl -s https://repo.mobian.org/mobian.gpg | sudo tee /etc/apt/trusted.gpg.d/mobian.gpg
Quick fix that worked for me:
Source: Matrix Mobian chat.
edit: to slow Smile
Strange, this command doesn't solve the problem here.
And it also looks like the key is pasted as text in the terminal (not into the file?).
I just copied the complete command from here multiple times and tried it multiple times.
Does anybody have an idea what could be the difference? Sad
Best Regards,
Dante
Using encrypted Mobian (bookworm) on pmOS CE Convergence PinePhone (3GB/32GB) as Daily Driver, and Beta Edition Convergence PinePhone (3GB/32GB) with encrypted Mobian (bookworm) as Backup device.
tee is splitter. The data read from stdin (in our case curl) is sent to a file and to stdout. Since tee is started as root (hence sudo tee), the file is written as root.
A cleaner way is:
curl -s https://repo.mobian.org/mobian.gpg | sudo tee /etc/apt/trusted.gpg.d/mobian.gpg > /dev/null
By sending the stdout to /dev/null, it is simply not displayed.
Can you please check if the timestamp of the file /etc/apt/trusted.gpg.d/mobian.gpg matches the time when you ran the command from above (w/ or w/o >/dev/null).
Ah, thank you!
The last change date of the file changes in both cases.
But I just noticed that the error message talks about repo.mobian-project.org, but the command gets it gpg key from repo.mobian.org Huh
Seem to be different domain names for the same server, but I guess apt does not accept such differences.
Did the mobian team change something?
(06-18-2022, 09:54 AM)jsch Wrote: tee is splitter. The data read from stdin (in our case curl) is sent to a file and to stdout. Since tee is started as root (hence sudo tee), the file is written as root.
A cleaner way is:
After installing curl the above command did the trick for my PP and PPP. Ta very muchly!
This finally worked for me Smile  :
curl -s https://repo.mobian.org/mobian.gpg.key | sudo tee /var/lib/extrepo/keys/mobian.asc
source: https://fosstodon.org/@mobian
Some don't have curl  and need wget
wget -O - repo.mobian.org/mobian.gpg.key | sudo apt-key add -
Professional tip, use tor
sudo apt install tor
with curl
torify curl -s https://repo.mobian.org/mobian.gpg | sudo tee /etc/apt/trusted.gpg.d/mobian.gpg
or wget
torify wget -O - repo.mobian.org/mobian.gpg.key | sudo apt-key add -
Can't update here as well. I can't install curl (I get 404 Not found) so I tried using wget above but it makes no difference. I still get:
Err:1 http://repo.mobian-project.org bookworm InRelease
Fetched 32.4 kB in 2s (20.5 kB/s)
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
this page suggests to do:
$ apt-key --keyring=/etc/apt/trusted.gpg.d/mobian.gpg mobian.gpg
But that dosen't work either and complains of an unknown option.
I tried to delete the key "951D61F2BC232697" with apt-key del . I then ran apt update but no success .
Even tried copying the mobian.gpg file into /etc/apt/ and /etc/apt/trusted.gpg.d/ . Ran apt update but no success :-( .
I did also try the command apt-key update but got:
Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
Warning: 'apt-key update' is deprecated and should not be used anymore!
Note: In your distribution this command is a no-op and can therefore be removed safely.
The /etc/apt/sources.list just shows
deb http://deb.debian.org/debian bookworm main
Internet connection on my pinephone mobian is ok btw.
UPDATE: Since I don't have curl I found I had to manually download and copy a file in /var/lib/extrepo/keys as someone did above.
$ wget repo.mobian.org/mobian.gpg.key
$ cp  $HOME/mobian.gpg.key /var/lib/extrepo/keys/mobian.asc
$ apt update
That worked for me to fix that error
*but*
Now apt seems to have many missing files:
$ apt-get dist-upgrade
Err:1 http://deb.debian.org/debian bookworm/main arm64 libgnome-bg-4-1 arm64 42.0-2
  404  Not Found [IP: 199.232.142.132 80]
Err:2 http://deb.debian.org/debian bookworm/main arm64 libgnome-bluetooth-ui-3.0-13 arm64 42.0-5
Err:3 http://deb.debian.org/debian bookworm/main arm64 libgnome-rr-4-1 arm64 42.0-2
Err:4 http://deb.debian.org/debian bookworm/main arm64 libnma-gtk4-0 arm64 1.8.38-1
Err:5 http://deb.debian.org/debian bookworm/main arm64 libsnapd-glib1 arm64 1.59-3
No matter how many times I try apt update I get these errors :-( .
ljones
  how to update mobian over tor vusra 13 6,943 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,243 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,346 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 4,247 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,340 11-28-2022, 03:30 PM
  Wifi issue since last update and held back updates goku499 11 5,333 09-21-2022, 02:39 PM
Last Post: Katsujinken
  [SOLVED] Lost Internet connectivity after recent update drh 3 1,867 09-11-2022, 09:24 PM
  Rescue Your Mobian post Update Aug22 faster fix to working guide biketool 9 4,772 09-05-2022, 12:10 AM
  Loving latest Mobian Update drh 11 5,096 08-22-2022, 12:19 PM
  Exclamation point in cellular icon after update Zebulon Walton 8 4,720 06-22-2022, 05:57 PM
Last Post: albafrati
