PinePhone Pro and inaccessible WiFi channels
I run my WiFi on channel 13 (2472MHz 20MHz width) and channel 142 (5700MHz, 40MHz width) because of high congestion. It's legal where I live and I never have any problem because of that.
PPP EE works fine with both bands out of the box with stock firmware, however most third party distributions like the latest mobian refuse to work with these channels, SSIDs are just not visible on the phone.
Changing channels to something more common works this around, but noticeably reduces performance for other devices because of congestion.
iw reg get lists these frequences as usable:
phy#0
country 99: DFS-UNSET
 (2402 - 2482 @ 40), (6, 20), (N/A)
 (2474 - 2494 @ 20), (6, 20), (N/A)
 (5140 - 5360 @ 160), (6, 20), (N/A)
 (5460 - 5860 @ 160), (6, 20), (N/A)
There is no regulation data in system so regulation setting is bogus, but installing CRDA and setting a proper regulation domain doesn't result in anything.
I've tried to remove stock "brcmfmac43455-sdio.bin", "brcmfmac43455-sdio.clm_blob" and "brcmfmac43455-sdio.pine64,pinephone-pro.txt" from /lib/firmware/brcm and use firmwares from different images for PPP and PBP instead, the best I could get to is using "brcmfmac43455-sdio.bin", "brcmfmac43455-sdio.clm_blob" and "brcmfmac43455-sdio.txt" from /lib/firmware/updates/brcm (note the updates subdirectory) of the stock system.
This way I can use my 5GHz network, but 2.4GHz is still not accessible.
Have anyone else run into this issue? Any ideas on how to fix?
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 14 1,854 6 hours ago
Last Post: diederik
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 45,191 02-13-2024, 02:54 PM
Last Post: fxc
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 842 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 974 11-23-2023, 08:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 708 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,727 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 19,464 09-10-2023, 03:19 AM
Last Post: fxc
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,460 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Cannot update new PinePhone Pro bent 6 3,511 05-15-2023, 02:43 PM
Last Post: alaraajavamma
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 1,528 05-12-2023, 12:58 PM
