PInebook not booting with eMMC enabled
Right now I have an SD card with Manjaro. If I disable eMMC and press reset, the power led goes red and then pinebook boots to Manjaro from SD. If I enable eMMC and press reset, power led goes off and nothing happens. I did check that eMMC is properly connected. What else can I try?
(10-21-2021, 03:35 PM)aragaer Wrote: Right now I have an SD card with Manjaro. If I disable eMMC and press reset, the power led goes red and then pinebook boots to Manjaro from SD. If I enable eMMC and press reset, power led goes off and nothing happens. I did check that eMMC is properly connected. What else can I try?
You have a "bad" uboot on emmc,, search order for uboot (really idbloader)  is SPI, emmc, uSD
Boot from SD, re-enable emmc, use the bind command (search forum), change uboot on emmc
Tried that -- when I boot and re-enable emmc, it's not visible in the system: /dev/mmc* only shows the SD card. When I try the commands in the https://wiki.pine64.org/index.php/Pinebo...nformation I'm getting "write error: No such device"
When I look in /sys/platform/devices, there is no ff330000.sdhci device, but there is ff330000.mmc device instead. I tried the following commands:
echo ff330000.mmc > /sys/bus/platform/drivers/sdhci-arasan/unbind
echo ff330000.mmc > /sys/bus/platform/drivers/sdhci-arasan/bind
These worked but no effect -- I only got a couple of error messages in dmesg.
I've got me an A-A USB cable to try the recovery process but failed to do that (probably didn't do the sequence right). Instead I tried again to boot with eMMC disabled and enable it once the boot started. I've stopped the U-boot from automatically booting and it showed that eMMC does indeed exist. After that I booted into Linux and did `dd if=/dev/mmcblk1 of=/dev/mmcblk2` (from SD card to eMMC). Rebooted again and it booted from eMMC.
That's good
Really, all you needed to do was copy mbr (1 sector) to sd, dd 1st 16M sd->emmc, restore emmc mbr
If it should be a little 'flakey' a non-booted distro has the /dev, /sys, /proc, /run
directories empty, just the top directories and the kernel fills them with virtual files
So, you may have to boot from sd, mount emmc and empty those directories
I've found mc (as root) the quickest and least hassle
  Pinebook Pro Initial Impressions kunger 443 596,102 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,367 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 449 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 340 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 326 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 262 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 722 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 810 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,746 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,354 12-15-2023, 02:11 PM
