Up to date guide on factory reset pinebook pro?
I'm not very familiär with flashing or installing operating systems on this type of machine (eMMC). Is there any written guides on how to do it? The best I've seen is the discussion in this thread .Do I need need an SD card (I don't have a spare)?
OK, my experiences
yes you most likely need another sd card, unless you are so lucky you can get a usb boot
This is a bit hit or miss
Whatever block device you are writing to has to be unmounted, and you are writing to whole block device, not a partition
I prefer something like .... xzcat someImage.xz | dd of=/dev/emmc bs=1M status=progress
You can unxz, takes more space and the original xz is deleted at the end
DO NOT neglect the bs=, writing 512B chunks takes forever, not so good for media either
All images have a uboot package in 1st 16M, all uboots are not created equal, it's a bit of a crap-shoot
You can rsync a booted sd, exclude sys dev proc run ,, make empty directories for them on the target
(and take care where "/" go,, ie rsync -a sd/bin/ emmc/bin, you don't want /bin/bin)
(and edit fstab extlinux.conf and mbr partition table to suit emmc AND install some uboot, 2 or 3 files)
all this done as root of course
Do use a reasonable quality sd card, lots of crap out there
  Pinebook Pro Initial Impressions kunger 443 593,285 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,334 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 420 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 316 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 304 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 240 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 695 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 777 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,688 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,288 12-15-2023, 02:11 PM
