open on-screen keyboard at will
hi :-)
applications like gvncviewer dont offer visible options to open the on-screen keyboard.
is there a way to open it?
maybe through the bar at the bottom?
kind regards
(06-11-2021, 03:21 PM)yogo1212 Wrote: hi :-)
It would be hugely advantageous to be able to pop up the keyboard at will.  Surely there could be some way to do that?
On Gnome you can just swipe up, and on Phosh and Windows 8/8.1/10 you can press the on-screen keyboard button.
Would be nice if something like either of those would be possible on Plasma (both desktop and mobile).
母語は日本語ですが、英語も喋れます(ry
  screen brightness Uturn 1 720 10-09-2023, 04:38 AM
Last Post: Eugo
  Manjaro: Settings doesnt open nbh 0 597 09-24-2023, 05:25 PM
Last Post: nbh
  screen brightness locked Uturn 0 677 07-07-2023, 09:38 AM
Last Post: Uturn
  Backup and Home Screen Tinkering on Phosh jakfish 0 866 02-24-2023, 12:56 PM
Last Post: jakfish
  No keyboard in Signal Desktop Kimberley van Buyten 4 2,409 10-16-2022, 10:25 AM
Last Post: Eugo
  Screen timeout makes alarm and timer unusable... Eugo 9 4,064 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,956 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,248 09-05-2022, 03:50 PM
Last Post: christev1
  Where do the keyboard layouts go? Eugo 1 1,112 08-31-2022, 11:03 AM
Last Post: Eugo
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 1,002 07-04-2022, 11:42 AM
Last Post: tuxmain
