Screen blocker is damaged ("loginctl unlock-session c1" problem)
Hi all, hope you can help me with this issue which is repeating eventually on my plasma mobile pinephone.
Sometimes, when the system suspends, and I try to unblock it, appears a black screen that says:
"The screen blocker is damaged and it cannot be unblocked; change to a virtual terminal, start session on it and execute the next command:
close the virtual terminal session typing Ctrl+D and change to the session you where using (Ctrl+Alt+F2)"
Do you know how can I fix this? I have searched on several webs but no success.
Thanks a lot.
I'm not sure, but I have the same problem.
*** EDIT ***
It's very naive in its workings, but I made a script to at least deal with the problem for the moment:
unlock.sh:
#!/bin/sh
while :; do
  echo "Unlocking...:
  sleep 2
done
Make the script executable:
chmod +x unlock.sh
Go into 'Settings' in the pulldown menu. Then, Autostart -> Add -> Add Login Script, and choose the script above.
I've only tested this for a few hours, but it's working so far.
This only happened when I did lock/unlock the phone and I reduced the occurrences by disabling auto-lock.
With the latest updates this now always happens and the phone will no longer show the UI and is completely unusable. "loginctl unlock-session c1" gets rid of the error screen but then the screen stays black. Restart sddm doesn't help either. Neither does a reboot.
I also that it takes a longer than usual (a few minutes) until it is connected with the network.
  screen brightness Uturn 1 712 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 669 07-07-2023, 09:38 AM
Last Post: Uturn
  SMS Problem hugh_barnard 2 1,296 05-10-2023, 04:24 AM
Last Post: acrux
Bug Problem with cameras/Megapixels? danimations 23 9,485 04-27-2023, 05:00 AM
Last Post: Eugo
  Backup and Home Screen Tinkering on Phosh jakfish 0 856 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen timeout makes alarm and timer unusable... Eugo 9 4,016 10-03-2022, 01:41 AM
Last Post: Eugo
  Disabling screen timeout for plasma mobile rp3 7 7,222 09-05-2022, 03:50 PM
Last Post: christev1
Question Problem with booting from SD card. Several errors LittleStone 0 839 09-04-2022, 02:34 PM
Last Post: LittleStone
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 997 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 6,291 03-05-2022, 06:21 AM
Last Post: dcinoz
