|Plasma] Blank screen + pointer, SDDM error
I updated my freshly-received PinePhone Beta, which was working correctly. Then after restart I have only a black screen with KDE logo and a mouse pointer. I can connect via SSH.
SDDM's journal:
Quote:Jul 04 19:19:14 plasma-mobile systemd[1]: Started Simple Desktop Display Manager.
Jul 04 19:19:14 plasma-mobile sddm[3221]: Initializing...
Jul 04 19:19:14 plasma-mobile sddm[3221]: Starting...
Jul 04 19:19:14 plasma-mobile sddm[3221]: Logind interface found
Jul 04 19:19:14 plasma-mobile sddm[3221]: Adding new display on vt 1 ...
Jul 04 19:19:14 plasma-mobile sddm[3221]: Loading theme configuration from ""
Jul 04 19:19:14 plasma-mobile sddm[3221]: Display server starting...
Jul 04 19:19:14 plasma-mobile sddm[3221]: Adding cookie to "/var/run/sddm/{5894bace-d8ca-4a6f-b885-770aa308b4c9}"
Jul 04 19:19:14 plasma-mobile sddm[3221]: Running: /usr/bin/X -nolisten tcp -background none -seat seat0 vt1 -auth /var/run/sddm/{5894bace-d8ca-4a6f-b885-770aa308b4c9} -noreset -displayfd 18
Jul 04 19:19:17 plasma-mobile sddm[3221]: Setting default cursor
Jul 04 19:19:17 plasma-mobile sddm[3221]: Running display setup script  "/usr/share/sddm/scripts/Xsetup"
Jul 04 19:19:17 plasma-mobile sddm[3221]: Display server started.
Jul 04 19:19:17 plasma-mobile sddm[3221]: Unable to find autologin session entry "plasma-mobile.desktop"
Jul 04 19:19:17 plasma-mobile sddm[3221]: Socket server starting...
Jul 04 19:19:17 plasma-mobile sddm[3221]: Socket server started.
Jul 04 19:19:17 plasma-mobile sddm[3221]: The configured theme "matcha-dynamic-sddm" doesn't exist, using the embedded theme instead
Jul 04 19:19:17 plasma-mobile sddm[3221]: Loading theme configuration from ""
Jul 04 19:19:17 plasma-mobile sddm[3221]: Greeter starting...
Jul 04 19:19:17 plasma-mobile sddm-helper[3312]: [PAM] Starting...
Jul 04 19:19:17 plasma-mobile sddm-helper[3312]: [PAM] Authenticating...
Jul 04 19:19:17 plasma-mobile sddm-helper[3312]: [PAM] returning.
Jul 04 19:19:17 plasma-mobile sddm-helper[3312]: pam_unix(sddm-greeterConfusedession): session opened for user sddm(uid=972) by (uid=0)
Jul 04 19:19:18 plasma-mobile sddm[3221]: Greeter session started successfully
Jul 04 19:19:18 plasma-mobile sddm[3221]: Message received from greeter: Connect
Jul 04 19:19:23 plasma-mobile sddm[3221]: Auth: sddm-helper exited with 11
Jul 04 19:19:23 plasma-mobile sddm[3221]: Greeter stopped.
I also tried lots of commands like "DISPLAY=0.0 startplasma-wayland -- vt1" or "DISPLAY=:0.0 kstart5 plasma-desktop", which give:
Quote:Failed to create wl_display (No such file or directory)
qt.qpa.plugin: Could not load the Qt platform plugin "wayland" in "" even though it was found.
This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, xcb.
Aborted (core dumped)
I reinstalled packages related to plasma, wayland, xorg, x11 or sddm. I also set my username instead of kde in the key Autologin.User in the file /etc/sddm.conf.d/00-default.conf. All this does not help.
Any ideas? Thank you.
  screen brightness Uturn 1 718 10-09-2023, 04:38 AM
Last Post: Eugo
  what is wrong with KDE plasma beta15 RC4? Uturn 8 1,620 10-02-2023, 05:07 AM
Last Post: Uturn
  screen brightness locked Uturn 0 675 07-07-2023, 09:38 AM
Last Post: Uturn
Exclamation My short experience with Manjaro Plasma Mobile anonymous 10 4,806 03-02-2023, 07:25 PM
  Backup and Home Screen Tinkering on Phosh jakfish 0 864 02-24-2023, 12:56 PM
Last Post: jakfish
  Manjaro plasma-mobile Beta 13 Uturn 13 4,916 01-25-2023, 04:15 PM
  Manjaro Plasma busted Chief 2 1,586 11-22-2022, 05:00 PM
Last Post: Chief
  Screen timeout makes alarm and timer unusable... Eugo 9 4,053 10-03-2022, 01:41 AM
Last Post: Eugo
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,954 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,244 09-05-2022, 03:50 PM
Last Post: christev1
