Screen timeout makes alarm and timer unusable...
...because the when the time runs out, it doesn't know it when it's suspended. It does tell you when you wake it up... and it was supposed to wake you up.
C'mon guys, this worked on any Nokia twelve years ago. Or probably even before. These two functions should wake up the Pine.
Isn't wake-mobile packaged for manjaro?
and birdie-alarm-mobile
ezik
How do I check that?
(09-13-2022, 04:59 AM)Eugo Wrote: How do I check that?
 both are  in the AUR
 both are git
 ezik
(09-12-2022, 02:07 PM)wibble Wrote: Isn't wake-mobile packaged for manjaro?
Now I saw what you meant here, and yes, it's there. But it's a separate app which should wake up the phone at a set time. To do so, I guess it uses some API. Well, can't the timer and the SMS app use the same?
IIRC wake-monile is the proof-of-concept by a gnome dev, and the plan is to add a general wake API to gnome for other apps to use, but they haven't got there yet.
(09-29-2022, 04:52 AM)wibble Wrote: IIRC wake-monile is the proof-of-concept by a gnome dev, and the plan is to add a general wake API to gnome for other apps to use, but they haven't got there yet.
Just let the guys know that there's one retired colleague who has trouble typing with fingers crossed... hoping they get it done soon.
On PostmarketOS this is working allready:
https://gitlab.com/postmarketOS/pmaports/-/issues/1170
And I think most of the needed things are all ready done:
https://gitlab.gnome.org/GNOME/gnome-clo...quests/146
So I guess most distros are just waiting that these things will be merged to upstream rather than creating own "duct tape fork"?
Well, perhaps I gave up on pmOs phosh too early. I'm pretty happy with manjaro phosh as it is, but now with winter coming I may have too much time on my hands, so I may give it a try.
  screen brightness Uturn 1 699 10-09-2023, 04:38 AM
Last Post: Eugo
  screen brightness locked Uturn 0 663 07-07-2023, 09:38 AM
Last Post: Uturn
  Remove Grayed-Out Alarm Icon from Panel? jakfish 2 1,292 03-02-2023, 09:49 AM
Last Post: jakfish
  Backup and Home Screen Tinkering on Phosh jakfish 0 848 02-24-2023, 12:56 PM
Last Post: jakfish
  Screen blocker is damaged ("loginctl unlock-session c1" problem) Gon 2 1,912 09-29-2022, 12:42 PM
Last Post: Firewave
  Disabling screen timeout for plasma mobile rp3 7 7,186 09-05-2022, 03:50 PM
Last Post: christev1
  |Plasma] Blank screen + pointer, SDDM error tuxmain 0 981 07-04-2022, 11:42 AM
Last Post: tuxmain
  How to return to "home screen" hiddenpotato 7 6,231 03-05-2022, 06:21 AM
Last Post: dcinoz
  Manjaro Welcome screen landscape JohanB89 2 2,180 11-12-2021, 01:13 AM
Last Post: acrux
  KDE Plasma Mobile screen scaling Uturn 1 1,806 10-29-2021, 06:59 AM
Last Post: Uturn
