No keyboard in Signal Desktop
Finally I got Signal Desktop working! But one thing, when I press the textbox to write, no keyboard is showing up! Is there a fix for?
At the moment, the only fix to this is to not use Plasma Mobile. It works better on Phosh, and I'd hope it works on Sxmo too.
The issue occurs due to Electron/Chromium's Wayland implementation not being all that compatible with the virtual keyboards we have - if you enable the ozone backend to not have the app look blurry on Phosh, you will struggle putting in a few letters (e.g. the o did not work for me, but I am not sure on which layout that occured).
Have you tried Axolotl?
AUR
https://aur.archlinux.org/packages/axolotl-bin
GitHub
https://github.com/nanu-c/axolotl
Same Problem here, and also with Threema Desktop. :/
Axolotl doesn’t boot at least under Manjaro plasma atm. :/ Big Grin
(09-02-2022, 07:46 AM)mikehenson Wrote: Have you tried Axolotl?
AUR
GitHub
Now that you mention it, axolotl behaves funny with cyrillic keyboard - the characters for u and t (namely, у, т) don't appear when typed, they just return the insertion point to the beginning of the line, like the home key would (on manjaro phosh). Other characters come up regularly.
I'm still waiting in the axolotl thread, to see if you guys caught up with Signal's dance. They seem to change protocol too often, almost like skype does every few months.
  New phone, KDE desktop settings reset on reboot zzb0 2 1,741 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 541 09-24-2023, 05:18 PM
Last Post: nbh
  alien desktop image Uturn 2 1,381 11-10-2022, 10:34 AM
Last Post: Uturn
  Axolotl signal client package lolgzs 27 19,525 11-02-2022, 04:55 AM
Last Post: shulamy
  Where do the keyboard layouts go? Eugo 1 1,090 08-31-2022, 11:03 AM
Last Post: Eugo
Sad Latest Manjaro breaks Keyboard Case (Again)? hollerpots 4 2,740 06-17-2022, 07:48 AM
Last Post: hollerpots
  Vivaldi Browser doesn't start keyboard for text entry tckosvic 1 1,989 05-24-2022, 11:32 PM
  How to convert your pinephone to a palmtop now that you have the clamshell keyboard rotwang 3 3,038 05-09-2022, 08:29 AM
Last Post: ragreenburg
  Keyboard case stopped working on pacman update rotwang 5 3,124 05-07-2022, 09:17 PM
Last Post: rotwang
  What is current best OS and desktop tckosvic 7 5,957 01-27-2022, 02:00 PM
Last Post: parry
