Rock64 CRUX-ARM (aarch64)
Source based Linux distribution CRUX-ARM adhering to ideology keep it simple, has its own package system, also supports the port system.
the image building system now supports slaсkwarearm, slarm64, crux-arm
crux-arm-3.6-aarch64-core-rock64-5.12.6-build-20210527.img.zst
crux-arm-3.6-aarch64-core-rock64-5.12.6-build-20210527.img.zst.sha256
# DDR version 1.16 20190528
In
LPDDR3
333MHz
Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB
ddrconfig:7
OUT
U-Boot SPL 2021.04-rk3328 (May 27 2021 - 20:41:34 +0300)
Trying to boot from MMC1
NOTICE:  BL31: v2.5(release):v2.5-dirty
NOTICE:  BL31: Built : 20:39:09, May 27 2021
NOTICE:  BL31:Rockchip release version: v1.2
U-Boot 2021.04-rk3328 (May 27 2021 - 20:46:24 +0300)
Model: Pine64 Rock64
DRAM:  4 GiB
PMIC:  RK8050 (on=0x50, off=0x01)
MMC:   mmc@ff500000: 1, mmc@ff520000: 0
Loading Environment from MMC... *** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
Net:   eth0: ethernet@ff540000
Hit any key to stop autoboot:  0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
1689 bytes read in 5 ms (329.1 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
51 bytes read in 4 ms (11.7 KiB/s)
51717 bytes read in 9 ms (5.5 MiB/s)
28723712 bytes read in 1249 ms (21.9 MiB/s)
libfdt fdt_getprop(): FDT_ERR_NOTFOUND
Failed to load '/boot/uInitrd'
Moving Image from 0x2080000 to 0x2200000, end=3e00000
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Device Tree to 00000000fcebb000, end 00000000fcf2ffff ... OK
Starting kernel ...
[    1.255013] rockchip-pinctrl pinctrl: pin gpio0-2 already requested by vcc-host-5v-regulator; cannot claim for vcc-host1-5v-regulator
[    1.255083] rockchip-pinctrl pinctrl: pin-2 (vcc-host1-5v-regulator) status -22
[    1.255117] rockchip-pinctrl pinctrl: could not request pin 2 (gpio0-2) from group usb20-host-drv  on device rockchip-pinctrl
[    1.255155] reg-fixed-voltage vcc-host1-5v-regulator: Error applying setting, reverse things back
[    3.053233] gpio-syscon ff100000.syscon:grf-gpio: can't read the data register offset!
[    3.251911] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed
CRUX-ARM 64b (rock64) (ttyS2)
rock64 login: root
Password:
Last login: Thu Jan 21 08:52:04 UTC 2016 on tty1
___  ___  _ _  _ _  ___  ___  ___  _____
|  _||  _|| | ||_'_||___|| .'||  _||     |
|___||_|  |___||_,_|     |__,||_|  |_|_|_|
                _    ___  ___
___  ___  ___ | |_ |  _|| | |
|  _|| . ||  _|| '_|| . ||_  |
|_|  |___||___||_,_||___|  |_|
donation   slarm64
crux-arm-3.6-aarch64-core-rock64-5.15.10-build-20211221.img.zst
crux-arm-3.6-aarch64-core-rock64-5.15.10-build-20211221.img.zst.sha256
donation   slarm64
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 621 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,434 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,787 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 594 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,473 12-07-2022, 08:22 PM
Last Post: luminosity7
