Unusable ROCKPRO64
Hi all,
            after running well for 25 days more or less, my rockpro64 is unusable. All USB ports and ethernet port are not working. I tried with many images, Manjaro, armbian... to top it all sometimes the startup finish with a kernel panic message.
I'm pretty sure that this is a hardware failure. Has anyone a similar experience? I'm very disgusted, the rockpro64 only ran for 25 days more or less. I have had others SBC, like raspberry pi, in the same place for years without problems.
Sad
(02-09-2021, 10:09 AM)drenedo Wrote: Hi all,
Sad
Please make sure that your power supply rated 12V 3A or 5A. Looks like your board not getting enough power. If you are using teh Raspberry Pi power power which is 5V, then for sure is under power.
Sad
The power supply is correct. 12V 5A.
Does it boot at all?
Could you hook up a serial connection like outlined here, and see what the boot init looks like?
https://forum.pine64.org/showthread.php?tid=6387
  RockPro64 automatically run after power recovery - my solution g2t 1 512 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 3,648 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,134 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,642 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,043 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 5,321 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,239 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 12,273 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 4,584 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 5,746 04-06-2023, 02:46 PM
