Installing Wifi drive for the RockPro64
I am trying to install Debian on the RockPro64 and I am having trouble getting the wifi drivers to be recognized by the installer. Without these I can not finish installing the OS.
At present I have tried formatting a USB stick to FAT32 and adding the files from here to a folder named "firmware" on the USB stick however the installer can not identify these files and keeps throwing an error stating the following files are missing:
brim/brcmfmac43455-sdio.bin
brim/brcmfmac43455-sdio.pine64,rockpro64-v2.1.bin
I can't install the OS without getting the wifi working so I am not entirely sure how to go about rectifying this problem. Does anyone have any suggestions? Should I be using a different OS? Is it a requirement to have a wired internet connection when you first install Debian?
If there are no other options I can go somewhere with a wired connection and install the OS and try and get the wifi firmware installed once the OS is already installed however I would like to avoid that if possible.
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 765 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 685 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,267 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 894 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,331 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,832 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,662 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,023 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,805 10-21-2022, 07:44 AM
Last Post: rapier1
  RockPro64 ddr clock speed causing system instability CypherShrugged 1 1,622 08-15-2022, 02:32 PM
Last Post: CypherShrugged
