No sound on Rockpro64 with OpenWrt
have a Rockpro64 with OpenWrt
I try to use the output jack, but I have no sound output detected
(02-17-2023, 09:24 AM)Patrice Wrote: have a Rockpro64 with OpenWrt
Hardware fix for software problem on Rockpro64 IT WORKS!!!! I  have sound coming from My Rockpro64 usb A 2.0(my family says)
Patrice I have the same problem as do many other about the audio Jack.  Though I dont use OpenWrt( note:not sure what it is), For me its not a big issue (Im deaf), but I like to use the computer so family can use it for Multimedia.  So The family was complaining no sound. which i couldnt care since I cant hear.  Well just off of a whim, I used to be an AirForce Tech, learned how to bypass and rewire things so troubleshooting problems like that and not of software are kind of a thing I enjoy.
I have a couple old Telescopes I use to stargaze and they need a 16bit interface so I need serial support on Meade and Takahashi scopes.
Ok the docking station I had with an old HP I used for this.  I simply plugged my USB A from the HP docking station into the USB A 2.0 on the Rockpro64 board, and plugged the speaker din plug into the headphone jack on the HP docking station and yes it works, the Family were Like yeah good dad it works great.  Oh and a bunch of stuff shows up in the audio streams of your audio controls - check it out.
Thats it. Hp part number HSTNN-S01X.  Its a usb docking station for audio video(serial) and 4 usb port as well as an internet plug for Hardwire.  Im sure other dockers work too!  but I havent tested them.  Dont buy the HSTNN-S02X - no audio jack there
  Installing Wifi drive for the RockPro64 John45595 0 314 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 766 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 685 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,268 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 894 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  Cant get rockpro64 working brasilikum 3 1,832 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,662 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,023 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,805 10-21-2022, 07:44 AM
Last Post: rapier1
  RockPro64 ddr clock speed causing system instability CypherShrugged 1 1,622 08-15-2022, 02:32 PM
Last Post: CypherShrugged
