RockPro64 and Neon
Does it actually have neon support? I notice that it's not listed in /proc/cpuinfo. If it is supported does anyone have a good way to identify it in a configure script so I can actually build a project that supports neon?
Chris
Yes, in armv8 nomenclature this is "asimd" in /proc/cpuinfo for advanced simd extensions. Your compilers will automatically pick it up, as far as I know, as it's a base feature of Armv8.0-A I believe.
The gcc manual confirms my belief here by straight up saying +simd is default on armv8-a:
[Image: simd.png]
So nothing special is needed in any configure script, any build for aarch64 will use simd, though auto-vectorisation might not occur on lower optimisation levels.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(10-21-2022, 03:34 AM)CounterPillow Wrote: Yes, in armv8 nomenclature this is "asimd" in /proc/cpuinfo for advanced simd extensions. Your compilers will automatically pick it up, as far as I know, as it's a base feature of Armv8.0-A I believe.
Okay, I think I know what is going on then. I've been working with the optimized poly1305 MAC code from floodyberry (github.com/floodyberry/poly1305-opt) and the problem seems to be that it just is too old to properly support armv8. Specifically in that the assembly was only written for 32bit processors. I was getting turned around buy an error message that, for some reason, made me think that it was a problem with the neon code and not the armv6 assembly.
Thanks!
  Installing Wifi drive for the RockPro64 John45595 0 313 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 762 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 684 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,262 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 894 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,329 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,828 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,657 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,023 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 ddr clock speed causing system instability CypherShrugged 1 1,620 08-15-2022, 02:32 PM
Last Post: CypherShrugged
