Bricked phone uninstalling apps. ?? ??
Brick
Today I chose to uninstall some apps I thought I'd never use like Maps, Calendar, Lollypop, Geary... I was thinking if a problem arose I'd just find it in Software and reinstall.
I believe trouble arrived when I uninstalled Evolution Notification this-or-that. (Which I noticed was running in RAM when I was doing nothing.) As soon as I did, both icons for SMS and phone calls turned into grey coins with ? in them, and did nothing when I tapped them.
I went to Software and couldn't find this Evolution Notifies etc. and I'm not too familiar with pacman but I figured out how to search and it didn't find anything. And then my Pinephone crashed (which is what it tends to do every so often) and after the Manjaro logo and the loading circle of dots under it, I see this:
[Image: 8b64f8dfe1d9e7dc8299561817c10278b8ad54aa...134624.png]
It stays on this screen until I do another hard reset, and the same thing happens again. I don't have a microSD to try and boot to it. Confused  Is there anything I can do except to factory reset?
it wants you to login usig your username and password. if you have a way to attach a keyboard (usb-c or the convergence bar) you can do so then start wayland manually
otherwise youre going to need to reset it
I don't know if Manjaro sets up ssh access by default, but that might be worth a try too. Reset involves booting from microSD.
  New phone, KDE desktop settings reset on reboot zzb0 2 1,770 10-15-2023, 10:19 PM
  How to create folders and re-org my phone desktop? A better "Image Viewer" app? nbh 0 563 09-24-2023, 05:18 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 3,519 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Locked Database-->Bricked Device _radv_ 8 2,929 12-02-2022, 11:32 AM
Last Post: fxc
  New issue with phone calls kmsgli 13 6,726 08-15-2022, 01:45 PM
Last Post: Gon
  Phone goes to sleep whilst audio playing new2pinephone 0 1,345 12-22-2021, 05:50 PM
Last Post: new2pinephone
  SMS apps in manjaro-plasma leave much room for improvement tckosvic 8 6,441 11-15-2021, 03:35 PM
Last Post: tckosvic
  After fresh install outbound phone calls not working. tckosvic 2 2,365 11-10-2021, 10:45 AM
Last Post: tckosvic
Music Can only hear/speak during a phone call when on speakerphone danimations 4 3,484 10-24-2021, 11:47 PM
Last Post: danimations
  Installed Sim phone not working kmk7x 3 2,707 10-24-2021, 11:43 PM
Last Post: bcnaz
