No wifi icon on desktop and no connectivity
TLDR; I recently had a failure installing i3 that has caused my wi-fi to stop working. I've cross-posted this https://forum.manjaro.org/t/no-wifi-icon...vity/37966
I recently tried to install i3 window manager and it caused some serious problems. I was unable to uninstall it with help from here https://forum.manjaro.org/t/will-not-boo...tall/37473 but afterwards the internet did not work. Actually it did not work while i3 was still installed so I think this installation failure caused the issue, not removing i3. This i3 thing really screwed things up.
I read this post https://forum.manjaro.org/t/unable-to-fi...ns/17232/2 and it seems I have the same behavior, on the same machine. But I do not get the errors when trying to reinstall drivers or restart the NetworkManager, but instead nothing happens. There is output with --verbose but I mean there is no change in the operation.
There is no wifi icon on the desktop and I can’t figure out how to get to the networking stuff. I’m new to Linux. From the desktop is there anything I can search? The only networking thing that comes up in Network Interfaces which I don’t know how to use. Where can I see network connections?
I’m not able to get
inxi --admin --verbosity=7 --filter --no-host
 file since I cannot get the file from the pine book since it’s offline but I can give shorter responses (or is there a way I can get it from one machine to another w/o wifi? I don’t have a USB unfortunately). I’ll post anything else that could help here.
PS - I’ve tried several times to make sure this not the wi-fi kill switch https://wiki.pine64.org/index.php/Pinebo...y_Switches  by trying both what I think is on and also off, then rebooting. This does nothing.
PSS- The battery icon has also disappeared.
Information Found newer firmware for broadcom wifi (brcmfmac43456-sdio) cobratbq 4 13,549 07-04-2025, 07:46 AM
Last Post: remph
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 19,036 06-26-2025, 09:20 PM
Last Post: reukiodo
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,418 03-15-2025, 01:47 AM
Last Post: frank_philip
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 5,450 11-14-2023, 10:57 AM
Last Post: trifleneurotic
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 2,112 02-16-2023, 10:58 AM
Last Post: cowsay
  5GHz wifi not working snorwood 11 18,849 01-16-2023, 03:41 PM
Last Post: ehcorn
  Pinebook Pro wifi not working Queliffrel 1 4,014 11-30-2022, 06:30 AM
Last Post: myself600
  WiFi stopped on Pinebook Pro after update tkudog 3 8,008 11-24-2022, 04:32 PM
Last Post: tkudog
  Archlinux - missing firmware for wifi adapter RudderDuck 9 16,278 11-07-2022, 04:56 PM
Last Post: wgahnagl
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 8,150 08-25-2022, 02:15 PM
Last Post: Niko
