webcam framerate bottleneck on linux?
Hi Folks,
I'm trying to understand the performance of the PBP webcam on linux. Here's a related thread from the hardware forum:
https://forum.pine64.org/showthread.php?tid=11460
The tldr is that `v4l2-ctl --list-formats-ext` makes it look like the camera ought to support 20fps at 1600x1200. And indeed, you can even set the camera to that, using v4l2-ctl or guvcview. But the results are clearly not 20fps. The picture quality (motion is blurred) suggests that the trouble is a long exposure time on the camera, even in bright light conditions. The bottleneck isn't the processing power of the PBP, since you can get perfectly good framerates at comparable resolutions with an external webcam.
Is there a v4l2 guru in the house who might have any idea of what's going on here?
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 364 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,531 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 676 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 160,965 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 1,218 11-28-2022, 05:03 PM
  Webcam not working in Manjaro with Cheese, but works in Armbian petaramesh 1 1,122 09-30-2022, 10:09 AM
Last Post: crazyquark
  Arch Linux ARM root filesystem SKiljan 24 21,096 09-24-2022, 03:11 AM
Last Post: alexandre
Information Install Void Linux with near-full-disk encryption dumetrulo 3 3,141 09-05-2022, 12:00 PM
Last Post: petersen77
  Help with Kali Linux wifi not working but works with Manjaro PineSupporter 2 2,427 08-25-2022, 02:15 PM
Last Post: Niko
  Problems installing/ booting a different Linux on PinebookPro v-man 3 3,114 03-22-2022, 06:37 PM
Last Post: pentamassiv
