Webcam not working in Manjaro with Cheese, but works in Armbian
The Pinebook pro webcam doesn't work either in Cheese or Kamoso with the preinstalled Manjaro, and it's definitely not a privacy switch issue as replies all over this forum suggest.
It actually works with any of these :
mpv /dev/video4
vlc v4l2:///dev/video4
guvcview-qt -d /dev/video4
It also works with webcamoid - that needs to be built from AUR although.
And it also works in a Jitsi echo test in Vivaldi : https://janus.conf.meetecho.com/echotest.html
However, the Webcam works out-of-the-box with Cheese using either Armbian or Twister OS (Both based on Ubuntu LTS), so I wonder what library or helper might be missing in Manjaro to get it working.
I tried to search for a while, but to no avail so far.
Any clue would be much appreciated.
I noticed the same - I suspect it might have something to do with Cheese trying to access /dev/video0 or something?
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 1 13,158 08-09-2025, 06:53 AM
Last Post: Sb2024
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 3,532 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  Armbian fix, current version now works Sb2024 0 2,349 08-08-2025, 08:49 AM
Last Post: Sb2024
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 5,122 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 5,848 02-19-2025, 12:49 PM
Last Post: zkajdan
  Slackware Linux working on PBP vxzero 0 3,421 06-05-2024, 04:30 PM
Last Post: vxzero
  Manjaro Sway Theme Broken Eighty8 1 3,664 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 6,131 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 3,313 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 9,004 12-13-2023, 07:22 PM
Last Post: trillobite
