Boot Manjaro lock screen language and key issues
Hi all,
New PBP user here with some questions.  I think I did something wrong on install, as the first lock/password screen that comes up on Manjaro KDE is in a language I don't understand.  I changed KDE's language settings to English and now, after that first lockscreen, everything is in English in KDE proper after the password has been entered, but I don't know how to change the language delayed in that first lock screen after boot when the machine is turned on.
Also, bizarrely, that first lockscreen's keyboard inputs require two or more presses for some keys, mostly vowels, in entering that initial boot screen password.  Again, once in KDE proper, the keyboard works normally without any double presses necessary.
Can anyone give me some guidance in how to fix this?  Thank you in advance.
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 334 02-18-2024, 08:54 AM
Last Post: 9a3eedi
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,749 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 327 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,135 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,206 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 403 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,225 11-23-2023, 07:37 AM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 885 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,018 08-21-2023, 09:10 PM
Last Post: vanessadonald
