No Wifi on new pinebook pro
I just received my new pinebook pro today. It booted up no problem. But there is no wifi? When I do ip addr in a terminal it only shows a loopback adapter no wifi adapter.
your help is appreciated.
geekyjm
It appears that some Pinebook Pros are coming from the factory with the privacy switch engaged.
See this;
https://wiki.pine64.org/index.php/Pinebo...y_Switches
Arwen Evenstar
Princess of Rivendale
My new Pinebook Pro also does not seem to be able to use Wifi; I've already tried the privacy switch and it does nothing, except it seems to turn off the bluetooth, which is working apart from the Wifi. Any ideas of why that would be? I was under the impression that both wifi and bluetooth were handled by the same AMPAK chip but perhaps I misunderstand?
Edit: It turns out the issue was largely PEBKAC. The privacy switch indicator and the privacy switch itself seem to be separate toggles; tapping META+F11 causes the privacy switch indicator to blink as if you'd toggled the Wifi without actually toggling it. One needs to hold META+F11 for three seconds before it will actually cause the privacy switch to toggle.
  About new OS over pinebook debian voje12 0 4 10 hours ago
Last Post: voje12
  Pinebook Pro Initial Impressions kunger 443 605,038 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,472 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 549 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 421 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 413 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 341 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 846 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 926 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 8,013 12-17-2023, 09:29 PM
Last Post: insideau786
