could be that: there is a new brightness scale with dts changes. first set the brightness to 100%, try 60% for "normal" usage.
cd /sys/class/backlight/edp-backlight
su (for me, sudo did not work)
cat br*
echo 3000 >brightness (or more, me 3200)
(I'm not 100% sure, funct-F2 didn't work, after this it did)
(03-13-2020, 09:58 PM)wdt Wrote: cd /sys/class/backlight/edp-backlight
cat br*
Can’t read the display, so dim that I can’t even see the mouse cursor!
I can get a terminal up with shortcut keys but still not able to read anything, it will probably be easier to reload my old version from the SD card...
Thanks for trying...
(03-13-2020, 07:45 PM)crocky Wrote: Just did the updates to the system and now things are really dark, can’t read a thing... Might have to plug the power in.... Hope that fixes it!
That did not do any good...
The capital M that first appears on the screen is bright for a split second then it goes very dull.. At the login screen it is very faint and I can’t read it...  Huh
After the updates, my screen came back very dim as well, but I was able to correct it using the keyboard (Fn-F2)
toggle to a tty
login
type your command and hit enter
profit
Here's my problem-- after that big round of updates, every so often when I'm browsing the web, when clicking a link or entering a URL, the screen locks. It happens in Chromium and qutebrowser, but not Firefox. I'll note that both Chromium and qutebrowser are built on webkit.
cat br*
got it working!
su
enter the root password
cat br*
200
echo 3000 > brightness
cat br*
3000
I had to turn on the Power Management keys to get the keyboard function key to work, Xfce Power Manager - Display
thanks
i use brightnessctl: brightnessctl s 100%
Hello Everyone,
I see many have this brightness reduced after kernel was updated to 5.6.
Here is a Solution.
Please increase the default brightness from the Power Management App in your respective DE.
For XFCE
Go to XCFE Power Management > Display > Increase the Brightness and Apply it.
I had documented it on Manjaro Forum though.
https://forum.manjaro.org/t/screen-dim-o...=spikerguy
For KDE-Plasma
Go to Energy Saving > Screen Brightness > Increase it to around 50% and apply it.
This will get set for every boot.
Thanks.
Manjaro ARM Team.
5.6.0-0.4-MANJARO-ARM
LibreOffice:
Version: 6.4.1.2
Build ID: 6.4.1-3
CPU threads: 6; OS: Linux 5.6; UI render: default; VCL: kf5;
Locale: en-US (en_US.utf8); UI-Language: en-US
Calc: threaded
When working with documents in Writer, I get random pastes of what appears to be in my clipboard. I likely pasted the text once, but it shows up in multiple random locations in the document. I can go through and clean them up (delete them), and I swear they pop up elsewhere! I can go to Manjaro's clipboard and clear it, and they still seem to creep in.
I have found a similar post regarding LibreOffice, and they pointed to hardware, or OS issues.
Anyone else see these issues? I have not noticed this happening in any other application, but then again, I don't write a lot of text in any other application.
Dennis Hoshield
PBPro/ANSI/Manjaro
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 90 05-31-2024, 09:42 AM
Last Post: SynthGal
  Official Debian support moonwalkers 63 54,276 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,673 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 438 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 2,246 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,876 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 480 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,400 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,534 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 91,794 12-08-2023, 11:25 PM
