Preinstalled Debian version?
I'm curious, since there appear to be a few options, what version/iteration of Debian has been chosen as the default OS for the PBP?
(07-25-2019, 10:15 AM)tophneal Wrote: I'm curious, since there appear to be a few options, what version/iteration of Debian has been chosen as the default OS for the PBP?
Debian 9.9. A lot of custom work has gone into this image, so there really wasn't time to update it for Buster.
Here is the image: https://github.com/mrfixit2001/debian_desktop/releases
I'm guessing at some point Debian 10 will be available? Any ideas how long that would be? (1st batcher for PBP, I am no dev but willing to test if I can)
Thx
J
Thx
J
At some point. You can upgrade to Buster manually, but it will break a number of things. If you're interested in figuring out how to fix everything that the upgrade breaks - document it - and share it, then that would be great.
I will probably give that a go, I'm not a dev but if I really mess it up I can just reflash it to stock I guess?
On Luke's video it did show using video out but what OS was that?
on the github for Debian:
UNTESTED:
  • USB-C video output
  • Cameras from PINE64 store
It may have been another OS build..or do they need to update the github? Smile
I believe this is the version you are thinking of:
  https://forum.pine64.org/showthread.php?tid=7269
Last commit to that github repo was 5 months ago but there have been OS updates since then, is there a different repo we should be looking at?
(08-18-2019, 11:50 PM)CampGareth Wrote: Last commit to that github repo was 5 months ago but there have been OS updates since then, is there a different repo we should be looking at?
Interesting.  Probably, because the repo only has the README.md, and not the changes from Rockchip's kernel and Debian 9.9 (stretch), etc.
The image file to download is in the releases:
https://github.com/mrfixit2001/debian_de...tag/190715
https://github.com/mrfixit2001/debian_de...715.img.xz
Are there tested arm64 distros. For me arm64 (not armhf) is essential. If both arm64 and armhf are being treated as equals, this would be great for me.
  Official Debian support moonwalkers 63 53,413 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,535 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,249 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,806 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,276 07-15-2023, 02:58 PM
Last Post: u974615
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,332 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,435 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,157 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 2,014 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 3,158 08-23-2022, 06:13 AM
Last Post: db579
