Chatty can no longer start since the last update
Has anybody else noticed that text messages are not arriving unless Chatty is open? Previously, Chatty would run in the background (You could see it running as a process under the Memory section of the Usage app) but not need to be open in the app carousel to receive messages. Now, I can only receive messages if the Chatty UI is also open.
I've updated the /etc/xdg/autostart/sm.puri.Chatty-daemon.desktop Exec line to this:
"Exec=env LD_LIBRARY_PATH=/usr/lib/aarch64-linux-gnu/purple-2 chatty %u"
This seems to restart Chatty's UI again after I exit the UI but I'm not seeing it keep the app alive when the UI is closed. Am I missing something?
Thanks!
Edit: Running Chatty 0.6.4 and bookworm on Mobian
  Chatty Matrix Decryption Key jojuma 2 364 02-26-2024, 12:48 PM
  Errors when start the system kubussz 2 673 11-21-2023, 11:07 AM
Last Post: kubussz
  Jabber with chatty user641 2 1,075 11-12-2023, 02:10 AM
Last Post: user641
  Auto start application on Phosh login Zebulon Walton 8 3,628 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Chatty does not work after suspend mode user641 4 2,050 07-18-2023, 10:43 AM
  how to update mobian over tor vusra 13 7,250 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,323 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,412 03-17-2023, 07:26 AM
Exclamation Impossible to login since the latest update anonymous 12 4,541 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,584 11-28-2022, 03:30 PM
