Installed Apps not opening
I have installed apps through the software application and have noticed that some apps do not open.  Specifically Pidgin I click on the app and it looks like its going to open but it just hangs.  Anybody else experience this ?
(10-06-2021, 08:27 PM)mmd604 Wrote: I have installed apps through the software application and have noticed that some apps do not open.  Specifically Pidgin I click on the app and it looks like its going to open but it just hangs.  Anybody else experience this ?
The "debris" from the failed start should be in the journal: try
journalctl -b
from the command line (Kings Cross) and see what is at the end. While in the terminal try start pidgin manually (probably type pidgin) and again you should see what the problem is.
HTH
One thing I've noticed is a lot of apps that do that behavior are not actually compatible with the pinephone yet. For almost every app I troubleshot that did that, they were actually crashing or stalling on start, and launching from a terminal would would only tell me where they got hung up.
It's a little frustrating that you can install whatever you want with no way to know if its broken, but all you can really do is try contacting the developer of the app to file a bug report.
(10-07-2021, 09:55 AM)gamerminstrel Wrote: One thing I've noticed is a lot of apps that do that behavior are not actually compatible with the pinephone yet. For almost every app I troubleshot that did that, they were actually crashing or stalling on start, and launching from a terminal would would only tell me where they got hung up.
Yeah, that is super annoying but what is almost worse is that there is no user feedback for an app that has crashed. There was an open issue on phosh about this but I don't think any progress has been made towards fixing it yet.
I think we're in an awkward early state still, where devs don't want to troubleshoot their more complex apps on Pinephone yet because phosh and Plasma Mobile are still such works-in-progress.
We're still seeing some simpler apps work though. Slowly but surely all the KDE/Gnome games are starting to fit on mobile, for example. Plasma Mobile is a bit more rough, but is a lot more open about their progress. You can freely join their matrix channel to talk to their devs even.
For sure. Plasma is definitely more rough around the edges but also is way more feature rich so I think they kinda took the approach of throwing everything in and then focus on fixing it and Phosh is focusing more on adding things slowly and making sure it all works. Personally I would love to use Plasma Mobile but right now it is so far from daily driver ready that it means I use Phosh even though it is basically just an app drawer.
  Keyboard not popping up on QT apps 3x5co 1 932 02-08-2024, 11:45 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 3,713 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 1,678 09-29-2023, 11:29 PM
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 800 08-30-2023, 03:23 PM
Last Post: jojuma
  PSA: anacron might be disabled if 2.3-33 was ever installed treebeard 0 775 11-21-2022, 02:32 PM
Last Post: treebeard
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 1,079 07-17-2022, 10:34 AM
Last Post: 3x5co
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 4,038 05-04-2022, 11:45 AM
Last Post: wibble
  Error - megapixels not opening user641 17 12,192 03-29-2022, 03:43 PM
Last Post: bcnaz
  Apps and SD Card biketool 2 2,286 03-06-2022, 09:47 AM
  Reskinning Apps for Mobile biketool 6 4,250 12-05-2021, 02:30 PM
