Apps and SD Card
I have noticed that most apps have a real difficulty using the SD card mounted in /media; as in they do not always have the ability to even browse but expect all media it will be playing and organizing to be stored in a default music or video directory in /home.
I think most users will be storing most multimedia on a SD card yet the only way to get for example Lolypop(music player) is to launch it from the command line with the SD directory holding my music.  Similar problems with Totem made worse by the absolutely minimal video codec support.
On desktop Linux I have options to choose apps like Audacious and VLC which are happy to let me manage my media rather than taking over organization with no other options when I just want playback.
Hello
In Lollypop --> Preferences --> Music you can add an additional folder Pick "Other...", select the small icon in the lower left corner, pick data ...
(03-06-2022, 07:54 AM)jsch Wrote: Hello
ok, I got there and used my soft keyboard to navigate and got it set, touch commands work but seem laggy.
adding to the wiki
https://wiki.mobian-project.org/doku.php?id=lollypop
  Keyboard not popping up on QT apps 3x5co 1 246 02-08-2024, 11:45 PM
  APN settings not working with new operator SIM card user641 1 1,036 03-01-2023, 04:43 PM
Last Post: anonymous
  What does handle SD card automount? mdk 1 1,044 01-29-2023, 03:15 AM
Last Post: mdk
  Giving certain audio apps priority on the lock screen and pulldown 3x5co 0 856 07-17-2022, 10:34 AM
Last Post: 3x5co
  New SD card won't auto-mount, will only mount as read-only 3x5co 3 1,731 07-16-2022, 02:28 PM
Last Post: dachalife
  Using lat/lon in GPS/GNSS apps and Messaging biketool 6 3,182 05-04-2022, 11:45 AM
Last Post: wibble
  How to flash a µSD-Card with Balena Etcher walter1950 1 1,315 01-22-2022, 02:06 AM
Last Post: bcnaz
  How to insert a SIM-Card and/or a µSD-Card walter1950 0 927 01-21-2022, 02:46 PM
Last Post: walter1950
  When I set SD card as /home, PP can't complete boot nelstomlinson 4 2,855 12-27-2021, 03:06 PM
Last Post: nelstomlinson
  Reskinning Apps for Mobile biketool 6 3,437 12-05-2021, 02:30 PM
