New SD card won't auto-mount, will only mount as read-only
I just got a 256gb, off-brand MicroSD card (it's actually Onn brand, which is a Walmart generic brand). Anyway, I formatted it on my computer, and everything seemed fine. But when I put it into my Pinephone, it won't mount. I can only mount it like so:
sudo mount -t ext4 -o ro /dev/mmcblk0p1 /storage/0000-0000/;
And if i put 'rw', it won't mount. It says 'bad superblock'. This is no matter how many times I reformat, if I recreate the partition table, If I disable journalling. I have even formatted it from inside the pinephone and it won't mount. Does anyone know what I can do to make my card auto-mount, and make it writable?
Sounds like the SD card is defective.
Yeah. I'm just going to mark this as solved because that is the most likely answer. I'll just return it and get a higher-quality card.
(07-16-2022, 09:36 AM)3x5co Wrote: Yeah. I'm just going to mark this as solved because that is the most likely answer. I'll just return it and get a higher-quality card.
I have the same problems with USB pen-drives or sd cards from the grocery store and I don’t know what it is; they never work.
Satisfied PinePhone, Pinebook Pro & PineTab2 owner; Thank you Pine64Team for your work!  Smile
  Screen auto-rotation sensitivity mdk 0 273 12-26-2023, 06:08 AM
Last Post: mdk
  Auto start application on Phosh login Zebulon Walton 8 3,392 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  APN settings not working with new operator SIM card user641 1 1,036 03-01-2023, 04:43 PM
Last Post: anonymous
  What does handle SD card automount? mdk 1 1,046 01-29-2023, 03:15 AM
Last Post: mdk
  Apps and SD Card biketool 2 1,902 03-06-2022, 09:47 AM
  How to flash a µSD-Card with Balena Etcher walter1950 1 1,316 01-22-2022, 02:06 AM
Last Post: bcnaz
  How to insert a SIM-Card and/or a µSD-Card walter1950 0 927 01-21-2022, 02:46 PM
Last Post: walter1950
  When I set SD card as /home, PP can't complete boot nelstomlinson 4 2,855 12-27-2021, 03:06 PM
Last Post: nelstomlinson
Question How to Save Read Only Files, Questions on Location lovepine88 8 7,814 06-12-2021, 06:08 PM
Last Post: ryo
  Unable to turn off auto brightness at times motox6 0 1,284 05-05-2021, 07:56 PM
Last Post: motox6
