PSA: anacron might be disabled if 2.3-33 was ever installed
from https://lists.debian.org/debian-user/202...00647.html :
Quote:If you run Debian testing/unstable and ever installed anacron 2.3-33 on
a systemd based system, then anacron will no longer be enabled and the
daily/weekly/monthly cron jobs will not be run until it is.
Since not all cron jobs have migrated to systemd timers, Debian
testing/unstable systems with systemd and anacron may be missing
some essential cron jobs, such as making backups of aptitude state.
To see if a system is affected you can use these commands:
zgrep -i anacron.*2.3-33 /var/log/apt/history.log*
systemctl status anacron.service anacron.timer
To re-enable anacron you can use these commands:
sudo systemctl enable anacron.service anacron.timer
sudo systemctl start anacron.service anacron.timer
More details of this problem are available in these bugs:
https://bugs.debian.org/1019554
https://bugs.debian.org/1020966
https://bugs.debian.org/1021496
v2.3-33 hit bookwork July 20 2022.
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,042 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 967 09-29-2023, 11:29 PM
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 609 08-30-2023, 03:23 PM
Last Post: jojuma
  Installed Apps not opening mmd604 5 4,030 10-08-2021, 09:29 AM
Last Post: ragreenburg
  Mobian can't see OpenVPN is installed. C0ffeeFreak 8 6,257 10-05-2021, 08:35 PM
Last Post: county93
  Dropbox cannot be installed daniel 4 4,397 08-02-2020, 04:03 PM
Last Post: hiimtye
  Mobian snd_seq not installed Hiraghm 2 3,318 07-22-2020, 12:08 AM
Last Post: Hiraghm
