Mobian snd_seq not installed
I've been trying to get Mame and a midi sequencer called "drumstick" to work on Mobian, and I keep getting an error where /dev/snd/seq file or directory not found.
Both crash while starting
Apparently the kernel was compiled without CONFIG_SND_SEQUENCER set, therefore snd_seq wasn't compiled into the kernel.
Can the flag be set in an upcoming update? I don't even know what the sound hardware on the Pinephone is.
Also there doesn't appear to be a modprobe for Mobian.
ScummVM works, (I played Full Throttle with full audio, no problems) and I suspect the error has something specific to do with MIDI sequencing.
edit: modprobe's there, I forgot to sudo when I ran it and just assumed it too was missing.
Thanks for reporting this issue! Sequencer support is now included in the latest kernel, once you upgrade and reboot Smile
(07-21-2020, 04:50 PM)a-wai Wrote: Thanks for reporting this issue! Sequencer support is now included in the latest kernel, once you upgrade and reboot Smile
BLESS YOU!
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,514 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 70 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,712 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 804 09-29-2023, 11:29 PM
  What actions needed to keep on mobian testing user641 3 1,687 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 580 09-01-2023, 11:29 AM
Last Post: Mahgue
  Why is Firefox ESR not listet under "Installed" in "Software" jojuma 0 553 08-30-2023, 03:23 PM
Last Post: jojuma
  how to update mobian over tor vusra 13 6,540 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,798 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 577 07-05-2023, 03:57 AM
Last Post: paulcarton
