11-23-2019, 12:10 PM
(This post was last modified: 11-23-2019, 12:16 PM by tsys.)
Hey all,
I've migrated bluetooth to the hci_uart driver and after hours of debugging managed to get it fully stable. Any stability issues reported with hciattach should be fixed, too.
I might have also fixed the instable WiFi in the process. Please let me know if you do still encounter instabilities.
tsys & @
DrYak, I too would like both 32 and 64 bit userland.
Most everything can stay at 32 bit. But, somethings may work better at one or the other.
Arwen Evenstar
Princess of Rivendale
Trying to boot this kernel with the stock Debian image that comes pre-installed. I built the defconfig, copied the Image and DTB onto /boot, modules into /lib/modules. It starts to boot, and then I see serial output, but suddenly after the following, it becomes garbage:
[ 12.051588] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
[ 12.065983] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22/connector
[ 12.068329] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22/connector
Has anyone else seen this? I'm using the 1500000 baud rate, and that works fine for u-boot output and early kernel output until this point. I've tried a few other common baud rates at this point, but nothing shows reasonable output.
