Help: Pinebook Pro will not enter sleep [Manjaro 20.04]
Question
Hello, I just received my Pinebook Pro yesterday which is the latest Manjaro branded version using the most current Manjaro ARM KDE 20.04 release. I finally finished installing & configuring all of my software/settings and thought I would test the machine - everything seems to work fine except SLEEP! (I also have a thread open about this issue on Manjaro forums since I'm not sure which would be the better place)
I have researched online and see a few others have encountered similar issues, but I wasn't able to find a fix that worked for me. Also, I haven't made any configuration changes or messed with suspend modes - I am fine with using s2idle, just want the screen to shut off and sleep when I close the laptop lid!
The crux of the issue is that the laptop starts to go to sleep, then it wakes immediately after - whether closing the lid, pressing the power button and choosing "sleep", or typing into terminal: "systemctl suspend". Long story short, it appears that either the dwmmc_rockchip [fe310000.mmc: pre_suspend failed for non-removable host: -38], or Device ff9a0000.gpu [failed to suspend: error -16] are causing the machine to abort going to sleep. Attached are the full logs:
May 28 12:15:59 feather polkitd[1013]: Registered Authentication Agent for unix-process:4179:71609 (system bus name :1.193 [/usr/bin/pkttyagent --notify-fd 5 --fallback], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale eaHello, I just received my Pinebook Pro yesterday which is the latest Manjaro branded version using the latest Manjaro ARM KDE 20.04 release. n_US.UTF-8)
May 28 12:15:59 feather ksmserver[1216]: lock called
May 28 12:15:59 feather kded5[1188]: bluedevil: About to suspend
May 28 12:15:59 feather NetworkManager[881]: <info>  [1590693359.2819] manager: sleep: sleep requested (sleeping: no  enabled: yes)
May 28 12:15:59 feather NetworkManager[881]: <info>  [1590693359.2822] device (p2p-dev-wlan0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
May 28 12:15:59 feather NetworkManager[881]: <info>  [1590693359.2842] manager: NetworkManager state is now ASLEEP
May 28 12:15:59 feather ksmserver[1216]: Lock window Id:  20971562
May 28 12:15:59 feather ksmserver[1216]: CreateNotify: 20971562
May 28 12:15:59 feather polkitd[1013]: Unregistered Authentication Agent for unix-process:4179:71609 (system bus name :1.193, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8) (disconnected from bus)
May 28 12:15:59 feather org_kde_powerdevil[1269]: powerdevil: Pausing all media players before sleep
May 28 12:15:59 feather ksmserver[1216]: CreateNotify: 54525956
May 28 12:15:59 feather kscreenlocker_greet[4185]: Qt: Session management error: networkIdsList argument is NULL
May 28 12:15:59 feather ksmserver[1216]: CreateNotify: 54525960
May 28 12:15:59 feather ksmserver[1216]: CreateNotify: 54525972
May 28 12:15:59 feather ksmserver[1216]: CreateNotify: 54525981
May 28 12:16:00 feather kscreenlocker_greet[4185]: kf5.kpackage: No metadata file in the package, expected it at: "/usr/share/wallpapers/Breath2/contents/images/"
May 28 12:16:00 feather kscreenlocker_greet[4185]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:76:9: Unable to assign [undefined] to QStringList
May 28 12:16:00 feather kscreenlocker_greet[4185]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75:9: Unable to assign [undefined] to int
May 28 12:16:00 feather ksmserver[1216]: CreateNotify: 54525983
May 28 12:16:00 feather ksmserver[1216]: CreateNotify: 54525985
May 28 12:16:00 feather ksmserver[1216]: MapNotify: 54525983
May 28 12:16:00 feather ksmserver[1216]: CreateNotify: 41947667
May 28 12:16:00 feather ksmserver[1216]: CreateNotify: 54525987
May 28 12:16:00 feather ksmserver[1216]: MapNotify: 20971562
May 28 12:16:00 feather systemd[1]: Reached target Sleep.
May 28 12:16:00 feather systemd[1]: Starting Suspend...
May 28 12:16:00 feather kscreenlocker_greet[4185]: UdevQt: unable to create udev monitor connection
May 28 12:16:00 feather ksmserver[1216]: CreateNotify: 54526000
May 28 12:16:00 feather kscreenlocker_greet[4185]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
May 28 12:16:01 feather kscreenlocker_greet[4185]: file:///usr/share/plasma/look-and-feel/org.kde.breath2.desktop/contents/components/VirtualKeyboard.qml:20:1: module "QtQuick.VirtualKeyboard" is not installed
May 28 12:16:01 feather ksmserver[1216]: CreateNotify: 54526011
May 28 12:16:01 feather systemd-sleep[4193]: Suspending system...
May 28 12:16:01 feather kernel: PM: suspend entry (s2idle)
May 28 12:16:02 feather kernel: Filesystems sync: 0.060 seconds
May 28 12:16:02 feather kernel: dwmmc_rockchip fe310000.mmc: pre_suspend failed for non-removable host: -38
May 28 12:16:02 feather kernel: Freezing user space processes ... (elapsed 0.004 seconds) done.
May 28 12:16:02 feather kernel: OOM killer disabled.
May 28 12:16:02 feather kernel: Freezing remaining freezable tasks ... (elapsed 0.002 seconds) done.
May 28 12:16:02 feather kernel: printk: Suspending console(s) (use no_console_suspend to debug)
May 28 12:16:02 feather kernel: PM: dpm_run_callback(): pm_runtime_force_suspend+0x0/0xd8 returns -16
May 28 12:16:02 feather kernel: PM: Device ff9a0000.gpu failed to suspend: error -16
May 28 12:16:02 feather kernel: PM: Some devices failed to suspend, or early wake event detected
May 28 12:16:02 feather kernel: OOM killer enabled.
May 28 12:16:02 feather kernel: Restarting tasks ... done.
May 28 12:16:02 feather kernel: PM: suspend exit
May 28 12:16:02 feather wpa_supplicant[923]: wlan0: CTRL-EVENT-DISCONNECTED bssid=38:94:ed:c5:0b:17 reason=3 locally_generated=1
May 28 12:16:02 feather systemd-networkd[518]: wlan0: Lost carrier
May 28 12:16:02 feather wpa_supplicant[923]: wlan0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
May 28 12:16:02 feather systemd-sleep[4193]: Failed to suspend system. System resumed again: Device or resource busy
May 28 12:16:03 feather systemd[1]: systemd-suspend.service: Main process exited, code=exited, status=1/FAILURE
May 28 12:16:03 feather systemd[1]: systemd-suspend.service: Failed with result 'exit-code'.
May 28 12:16:03 feather systemd[1]: Failed to start Suspend.
May 28 12:16:03 feather systemd[1]: Dependency failed for Suspend.
May 28 12:16:03 feather systemd-logind[886]: Operation 'sleep' finished.
This suspend issue is happening on my eMMC main installation, but also happens on a fresh SD card install of Manjaro ARM KDE 20.04 as well with the same error messages as above. Also, interesting to note that this Pinebook Pro also has actually successfully entered sleep state before - it will randomly work maybe 5% of the time, which hopefully is a good sign this is a software issue that can be fixed.
Loving this little machine other than this issue - Any help is greatly appreciated, thank you!
Help: Pinebook Pro will not enter sleep [Manjaro 20.04] - by EverythingIsInput - 05-28-2020, 02:41 PM
  Debian on Pinebook Pro u974615 7 1,138 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 301 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,666 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,775 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 351 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,179 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,262 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,453 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 424 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,291 11-23-2023, 07:37 AM
