iommu page fault causes blank screen under Manjaro 20.04?
I've found lots of instances on the web of people having tracker using a tremendous amount of CPU and memory. Can you try disabling tracker to see if that is the problem. Or perhaps also ask this in the Manjaro arm forum.... . I believe tracker and tracker-miner packages are installed with GNOME. I am running the KDE Plasma version of 20.04, and don't have tracker running, nor am I seeing the problem you are having.
RE: iommu page fault causes blank screen under Manjaro 20.04? - by belfastraven - 04-11-2020, 02:18 PM
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 347 02-18-2024, 08:54 AM
Last Post: 9a3eedi
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,765 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 337 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,160 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 906 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,024 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,985 08-21-2023, 09:08 PM
