Manjaro and Arch repository with privacy oriented software
I intend to add signal-desktop and wire-desktop next.
If there are any questions, problems or requests, I'm all ears Smile
If you have any packages that might be worth adding (be it because it would take days to build or because it would fit the privacy / security focus of the repo), just ask. I have to spin up an aarch64 instance "in the cloud" for the heavier builds every now and then anyway, so I could as well make use of it Smile
It should be avoided to add to many packages to the repo "just cause", as that would increase the maintenance burden and could thus lead to the important packages not being kept up to date as much as possible, so one might have to see where it goes.
For now, I'll keep adding a few packages that I already build all the time anyway, so the the increased effort on my part is marginal.
RE: Manjaro and Arch repository with privacy oriented software - by llsf - 03-18-2020, 03:07 AM
  By the way, yay arch... KC9UDX 4 734 03-30-2024, 10:27 PM
  Manjaro Sway Theme Broken Eighty8 1 290 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,765 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 337 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,160 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,237 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 415 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 906 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,024 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,985 08-21-2023, 09:08 PM
