By the way, yay arch...
Of course I run NetBSD on my Pinebooks Pro, but I kept Manjaru on my wife's.  She doesn't update it; so twice a year I do.  I kind of expected the totally broken boot that I've had before doing this.  But this time was bizarre.  Halfway through the updates it prompted me for the current user's password.  It was at that point I discovered that all user passwords had been deleted/changed/#?
So I used my PBP to create an emergency boot SD and created new passwords for all users on the Manjaru-PBP-in-question.
Now, I can continue updating, but I am faced with "could not satisfy dependencies: kxmlgui required by libkipi - kservice required by libkipi".
What is the way to recover from this, which I presume is due to too much time between updates?
:wq
[ SRA accepts you ]
i would try to remove the package and install again
or use the ignore flag to update the rest and then try again without the flag
ezik
(12-23-2023, 11:38 PM)shulamy Wrote: i would try to remove the package and install again
ezik
Thanks.  I'll try that.
:wq
[ SRA accepts you ]
It did work; I wonder why that package was installed anyway.  I'm glad removing it didn't hose the whole system; arch must be improving.
Thanks again.
:wq
[ SRA accepts you ]
Well this is infuriating: I installed Manjaru anew with the official image from the website. It works as is, but can't be updated (and thus new packages can't be installed) because it's too far out-of-date. Reason #12 why normally I won't touch "rolling releases" with a ten foot pole.
:wq
[ SRA accepts you ]
  PineBook HOW TO REINSTALL ARCH-Manjaro. Ice-O-Star 0 919 10-22-2022, 10:46 AM
Last Post: Ice-O-Star
  Arch Linux ARM root filesystem SKiljan 24 20,862 09-24-2022, 03:11 AM
Last Post: alexandre
  Booting Arch from USB lorebett 6 3,012 09-18-2022, 11:35 AM
Last Post: lorebett
  Manjaro and Arch repository with privacy oriented software as400 86 113,938 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  Help with bypassing Arch check in Pamac JoshTheTofu 2 2,150 11-26-2021, 07:32 AM
Last Post: user18130814200115
  Arch ARM iso for Pinebook Pro hanmorten 2 3,969 07-09-2020, 01:37 AM
Last Post: hanmorten
  boots not after try installing arch definitiv. 3 5,351 06-17-2020, 04:06 PM
Last Post: definitiv.
  Cant boot into home-rolled Arch Linux image craftkiller 4 4,670 02-25-2020, 12:58 PM
Last Post: craftkiller
  Is it possible to install Arch linux? alxndr.psclt 2 5,215 01-09-2020, 06:45 PM
Last Post: alxndr.psclt
