new battery.
(02-27-2020, 10:01 PM)pjsf Wrote: Just got a new battery for the fun of it, and to have a spare. Basically I just got the cheapest one from the local ebay resellers (under Au$ 14).
listed as an  "EB-BJ700BBC".
Seems to work quite well, only problem was that it a had two small plastic nubs at the bottom (i think they must fit into some positioning holes on the inteded handset) which stopped it from fitting. After I filed those off it it just drops in and seems quite tight.
Who knows how it will perform, but the form factor is right.
Nice, thanks for the info! I tend to look for a higher capacity battery now and then, but so far has not pulled the trigger. Being able to fit a 3700-4000mah battery would be a nice upgrade, however most of the large capacity batteries I have found don´t really look that "trustworthy".
"- is there already a tool for overclocking it desperately?"
new battery. - by pjsf - 02-27-2020, 10:01 PM
RE: new battery. - by murak - 02-28-2020, 01:20 AM
RE: new battery. - by pjsf - 02-28-2020, 06:57 PM
  Megi's Kernel and Battery Life biketool 3 2,221 01-09-2023, 11:33 PM
Last Post: Canyonless
  PinePhone Pro battery life Barugon 17 15,942 07-29-2022, 09:23 AM
Last Post: prog-amateur
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,577 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 7,496 04-05-2022, 06:11 AM
Last Post: Anna
  The modem switch affects the connection to battery? JohnDoe 2 2,110 03-30-2022, 12:02 AM
Last Post: JohnDoe
  improve battery life on pine phone beta? taoschx 0 1,097 02-28-2022, 06:24 AM
Last Post: taoschx
  Guide to power off the Pinephone on low battery Ulfnic 1 1,605 02-06-2022, 05:16 AM
Last Post: Ulfnic
Question Is there a way to increase the battery life of the PinePhone? Avisando 18 12,714 01-22-2022, 11:55 PM
Last Post: bcnaz
  Battery Charger? JesusGod-Pope666.Info 9 6,733 12-01-2021, 09:00 AM
Last Post: JesusGod-Pope666.Info
  Battery life: Maybe really a hardware issue? KNERD 34 22,459 09-23-2021, 01:11 PM
