postmarketOS fixed battery issues
I recently got the PinePhone convergence, and it had a lot of the common problems with Manjaro Plasma, including the battery not charging fully and only holding a charge for a few minutes unless plugged in. Battery drained overnight even with phone turned off, as reported by a number of people. I got the phone, fooled with it for a day, then got updates via the terminal; after that the phone not only didn't charge well but it would crash instantly when unplugged. Obviously, this wasn't working.
So I decided to try the postmarketOS (release v21.12 for PinePhone), put it on an SD card, loaded it onto the phone, and bang: not only a great lightweight os that actually works, but it fixed the battery issues. Now the phone charges 100% and most importantly holds a charge for several hours. Don't know if anyone else has had this experience, but it sure worked for me. Worth a try if you are having those battery issues, and can use a more minimal os. Download from postmarketos.org/download/
Any idea whether it plays well with the keyboard module?
it doesn't get happy
it doesn't get sad
it just runs programs
  Multiple issues with the Pinephone MTXP 12 2,253 12-28-2023, 07:55 AM
Last Post: MTXP
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 2,061 07-16-2023, 11:14 AM
Last Post: kebab
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 1,447 05-10-2023, 03:31 AM
Last Post: fxc
  Error while dist upgrade PostmarketOS shellchocolat 0 708 03-16-2023, 02:56 AM
Last Post: shellchocolat
  New Phone Opening Issues LuluFrance 5 2,149 03-15-2023, 05:33 AM
Last Post: anonymous
  Megi's Kernel and Battery Life biketool 3 2,120 01-09-2023, 11:33 PM
Last Post: Canyonless
  How to install fbkeyboard on PostmarketOS? Ulfnic 1 1,094 09-12-2022, 07:49 PM
Last Post: Ulfnic
  PinePhone Pro battery life Barugon 17 15,502 07-29-2022, 09:23 AM
Last Post: prog-amateur
  PinePhone sound issues Chief 4 2,788 07-05-2022, 07:58 PM
Last Post: Chief
  Pinephone 64 Issues of a new user US Notheast as of April 2022 scrwbigtek 9 5,470 05-03-2022, 04:18 PM
Last Post: scrwbigtek
