The modem switch affects the connection to battery?
(Sorry if something is wrong because I'm new here and English is not my native language)
As we all know, if you toggle the modem privacy switch the modem will be disconnected from the rest of the phone, but will it be completely powered off or only be running disconnected from the rest of the system?
It still drains battery?
(03-29-2022, 08:55 PM)JohnDoe Wrote: (Sorry if something is wrong because I'm new here and English is not my native language)
do you mean software switch or hardware switch? assuming hardware switch.
hardware switch disconnects power to the eg25-g chip, technically speaking usb connection is there but powerless chip does not communicate. you could check this https://files.pine64.org/doc/PinePhone/P...ematic.pdf . search for SW1-A. hardware switch will totally power off the modem chip.
software switch leaves modem chip running some way, which could be an issue some cases.
Yes, I was talking about the hardware switch. Thanks for giving a complete answer that includes the software as others may have this question.
  Modem white list aular 7 896 02-13-2024, 04:35 PM
Last Post: aular
  qcell modem id aular 6 861 01-15-2024, 10:05 PM
Last Post: aular
  Temporary fix for Modem Not Coming Back on in SXMO Postmarketos Pinephone kebab 2 2,098 07-16-2023, 11:14 AM
Last Post: kebab
  Modem gets disabled on every suspend jojuma 5 1,809 03-27-2023, 02:51 AM
Last Post: jojuma
  Modem audio settings jack1 2 1,309 02-04-2023, 04:01 PM
Last Post: jack1
  Megi's Kernel and Battery Life biketool 3 2,142 01-09-2023, 11:33 PM
Last Post: Canyonless
  PinePhone Pro battery life Barugon 17 15,618 07-29-2022, 09:23 AM
Last Post: prog-amateur
  get a KVM switch from pinephone cybercommunist 0 811 06-29-2022, 02:14 AM
Last Post: cybercommunist
  postmarketOS fixed battery issues Deadladyofclowntown 1 1,535 06-23-2022, 02:44 PM
Last Post: zer0sig
  Phone won't suspend, battery drains quickly nelstomlinson 12 7,222 04-05-2022, 06:11 AM
Last Post: Anna
