OpenSUSE with XFCE/ GNOME3 now available
#32
(12-18-2020, 11:30 AM)Surehand53 Wrote: It looks like the Pinebook Pro is on the way to get official openSuse support.
https://en.opensuse.org/HCL:Pinebook-Pro-RK3399
So far I get a blank screen after booting, but it looks as if the system started (the power button to turn it off works)
Probably a small thing needs tweaking..
So, I booted the sd card with UART attached and it turns out it starts all right.
You get a GRUP menu (does GRUP work for PBP?) and when you choose Tumbleweed this message appears and then it stops:
  Booting a command list
Loading Linux 5.10.1-1-default ...
Loading initial ramdisk ...
EFI stub: Booting Linux Kernel...
EFI stub: EFI_RNG_PROTOCOL unavailable, KASLR will be disabled
EFI stub: Using DTB from configuration table
EFI stub: Exiting boot services and installing virtual address map...
Any suggestions how to progress ?
These are the start commands, if that helps;
setparams 'openSUSE Tumbleweed'        │
│        load_video        │
│        set gfxpayload=keep        │
│        insmod gzio        │
│        insmod part_gpt        │
│        insmod btrfs        │
│        if [ x$feature_platform_search_hint = xy ]; then                                                     │
│          search --no-floppy --fs-uuid --set=root  17fab815-2ec8-468c-9391-25d6a1df430a                      │
│        else        │
│        fi        │
│        echo        'Loading Linux 5.10.1-1-default ...'                                                     │
│        $linux        /boot/Image-5.10.1-1-default root=UUID=17fab815-2ec8-468c-9391-25d6a1df430a rw  ${extr\│
│a_cmdline} loglevel=3 splash=silent plymouth.enable=0                                                        │
│        echo        'Loading initial ramdisk ...'                                                            │
│        $initrd        /boot/initrd-5.10.1-1-default
RE: OpenSUSE with XFCE/ GNOME3 now available - by Surehand53 - 12-28-2020, 11:44 AM
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,161 10-10-2022, 06:22 AM
Last Post: maxjrh
  Official openSUSE: U-Boot, dtb and graphics Jojonintendo 1 2,615 06-12-2021, 08:38 AM
Last Post: Jojonintendo
  Error Log has a few scetchy things. Manjaro Xfce SpaceLord 0 1,562 05-23-2021, 10:49 AM
Last Post: SpaceLord
Heart PBP Arrives Tmmro, Manjaro 20.12 xfce, Seeking Install Notes/Tips/Tricks/Advice SpaceLord 4 4,524 03-01-2021, 06:00 PM
  XFCE Window Tiling Telefza 2 4,672 12-04-2020, 03:07 AM
Last Post: Telefza
  [Release] Fedora 32 Workstation, KDE, Xfce, and Cinnamon Images wideawake 20 20,574 11-28-2020, 02:14 PM
Last Post: Tharadash
  Fedora GNOME3 now available Luke 46 66,455 11-20-2020, 07:17 PM
Last Post: DarrowAtreides
  Manjaro XFCE MPV Hardware Acceleration p3pp3r 2 5,550 10-14-2020, 08:52 PM
Last Post: p3pp3r
  Manjaro XFCE vs. Manjaro KDE pawlinski 0 2,378 09-02-2020, 06:49 AM
Last Post: pawlinski
  Manjaro XFCE: Vastly improved experience with Picom (Compton) compositor jichu4n 2 12,883 07-20-2020, 01:43 PM
Last Post: jichu4n
