Manjaro XFCE: Vastly improved experience with Picom (Compton) compositor
TL;DR: Switched to Picom compositor instead of XFCE's built-in compositing, and everything feels MUCH smoother.
Currently running a vanilla Manjaro ARM XFCE install on my Pinebook Pro. While everything mostly works fine, I've been bugged by how the experience somehow just feels a bit sluggish. In particular, scrolling in Chromium and Firefox is visibly laggy even for fairly lightweight websites.
I would've assumed it's just how the hardware is, but I've seen some videos of Manjaro ARM KDE on the Pinebook Pro that seem to suggest otherwise. Additionally, I happen to have a Chromebook with the same Rockchip RK3399 SoC (ASUS Chromebook Flip C101PA) and browsing and scrolling around on the Chromebook feels much much smoother in comparison.
After some digging around, I started to suspect the lag / sluggishness was related to a lack of OpenGL acceleration in the XFCE desktop. So long story short, I tried switching out XFCE's built-in compositing for the Picom compositor (apparent successor to Compton), and was blown away by how much it improved the experience. Scrolling in Chromium and Firefox felt much smoother, and navigating around apps end menus just felt much snappier.
So really wanted to share this result, and curious to know if switching to Picom may help other Manjaro ARM XFCE users as well.
Steps I used to set up Picom:
1. pacman -Sy picom
2. XFCE Settings -> "Window Manager Tweaks" -> "Compositor" -> uncheck "Enable display compositing"
3. XFCE Settings -> "Session and Startup" -> "Application Autostart" -> add item with the command "picom"
4. Start in current session with "picom -b".
The default settings seemed to work fine for me, so I haven't found the need to create a config file to tweak settings yet.
My setup: manjaro-release 20.07-1 (upgraded from 20.04 install), kernel linux-pinebookpro 5.7.0-3, mesa 20.1.3-1, xfwm4 4.14.2-1
References:
- Using Compton for a tear-free experience in Xfce in Manjaro Wiki
- Picom in Arch Linux Wiki
(07-16-2020, 02:13 PM)jichu4n Wrote: TL;DR: Switched to Picom compositor instead of XFCE's built-in compositing, and everything feels MUCH smoother.
1. pacman -Sy picom
References:
Much improved indeed - finally smooth scrolling with Firefox! Thank you for sharing this.
(07-18-2020, 02:40 PM)perceg Wrote: Much improved indeed - finally smooth scrolling with Firefox! Thank you for sharing this.
Nice!! Glad to hear it's working for others as well.
  Manjaro Sway Theme Broken Eighty8 1 168 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,607 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 214 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,916 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 291 12-07-2023, 03:11 PM
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 746 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,913 08-21-2023, 09:10 PM
Last Post: vanessadonald
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 1,853 08-21-2023, 09:08 PM
  Manjaro - HIbernate - brcmfmac clk issue pompeyPinePro 1 709 08-18-2023, 02:06 AM
Last Post: juliamenendez
