Fedora GNOME3 now available
#37
(06-26-2020, 03:41 PM)TDC_PBP Wrote:
(03-23-2020, 08:57 AM)rossk Wrote: I installed the latest kernel (`dnf install kernel`), and it seems like the next thing to do is update /boot/extlinux/extlinux.conf.
There's a warning not to manually edit the file, with the recommendation to use `u-boot-update`-- but I don't see a fedora package that provides that command?.
I'll hunt around a bit more, but I might just ignore the warning and edit it by hand anyways.
This is probably a dumb question, but what does dnf install kernel do exactly? If it upgrades the Kernel, why is the kernel not automatically updated with sudo dnf upgrade? I haven't found an answer online anywhere. Thanks!
Same here. I didn't find any package that provides u-boot-update, there seems to be a uboot utils package, but that's it. I only managed to break my system as i tried to make a new initframs.
Right now im only thinking that whatever created this uboot setup for fedora was an external tool. I believe we need to look for instructions on how to generate a new u-boot setup, which in turns needs a new initframs with the new kernel.
Can someone point to instructions on how to do this?
Fedora GNOME3 now available - by Luke - 02-06-2020, 06:03 PM
RE: Fedora GNOME3 now available - by jpakkane - 02-11-2020, 04:10 PM
RE: Fedora GNOME3 now available - by tuxfanou - 02-13-2020, 03:55 AM
RE: Fedora GNOME3 now available - by saeioul - 02-16-2020, 09:49 PM
RE: Fedora GNOME3 now available - by tuxfanou - 02-17-2020, 09:46 AM
RE: Fedora GNOME3 now available - by saeioul - 02-17-2020, 10:51 AM
RE: Fedora GNOME3 now available - by tuxfanou - 02-19-2020, 09:59 AM
RE: Fedora GNOME3 now available - by tophneal - 02-19-2020, 10:12 AM
RE: Fedora GNOME3 now available - by tuxfanou - 02-19-2020, 10:20 AM
RE: Fedora GNOME3 now available - by aptupdate - 02-21-2020, 04:01 AM
RE: Fedora GNOME3 now available - by saeioul - 02-20-2020, 12:07 PM
RE: Fedora GNOME3 now available - by madalin - 02-19-2020, 03:34 PM
RE: Fedora GNOME3 now available - by tuxfanou - 02-20-2020, 02:34 AM
RE: Fedora GNOME3 now available - by erchache2000 - 02-21-2020, 04:36 AM
RE: Fedora GNOME3 now available - by tophneal - 03-05-2020, 09:44 AM
RE: Fedora GNOME3 now available - by wove - 03-06-2020, 08:23 AM
RE: Fedora GNOME3 now available - by tophneal - 03-06-2020, 01:02 PM
RE: Fedora GNOME3 now available - by tedium - 03-06-2020, 08:39 PM
RE: Fedora GNOME3 now available - by digeratus1. - 03-17-2020, 10:05 AM
RE: Fedora GNOME3 now available - by tophneal - 03-17-2020, 10:10 AM
RE: Fedora GNOME3 now available - by digeratus1. - 03-17-2020, 07:23 PM
RE: Fedora GNOME3 now available - by tophneal - 03-18-2020, 06:15 AM
RE: Fedora GNOME3 now available - by digeratus1. - 03-19-2020, 08:28 AM
RE: Fedora GNOME3 now available - by tophneal - 03-19-2020, 12:57 PM
RE: Fedora GNOME3 now available - by digeratus1. - 03-20-2020, 11:00 AM
RE: Fedora GNOME3 now available - by rossk - 03-20-2020, 01:40 PM
RE: Fedora GNOME3 now available - by digeratus1. - 03-21-2020, 07:18 AM
RE: Fedora GNOME3 now available - by bus-error - 03-22-2020, 03:30 PM
RE: Fedora GNOME3 now available - by rossk - 03-23-2020, 08:57 AM
RE: Fedora GNOME3 now available - by TDC_PBP - 06-26-2020, 03:41 PM
RE: Fedora GNOME3 now available - by saeioul - 06-28-2020, 01:43 PM
RE: Fedora GNOME3 now available - by aptupdate - 07-01-2020, 03:35 PM
RE: Fedora GNOME3 now available - by rgab - 03-25-2020, 08:26 PM
RE: Fedora GNOME3 now available - by csa3d - 04-09-2020, 06:29 PM
RE: Fedora GNOME3 now available - by tophneal - 04-30-2020, 06:29 AM
RE: Fedora GNOME3 now available - by linuxfreund - 06-03-2020, 04:13 AM
RE: Fedora GNOME3 now available - by cefre00 - 06-25-2020, 01:09 AM
RE: Fedora GNOME3 now available - by aptupdate - 07-25-2020, 12:38 PM
RE: Fedora GNOME3 now available - by linuxfreund - 09-01-2020, 03:26 AM
RE: Fedora GNOME3 now available - by aptupdate - 09-27-2020, 07:42 AM
RE: Fedora GNOME3 now available - by linuxfreund - 09-27-2020, 11:30 AM
RE: Fedora GNOME3 now available - by aptupdate - 09-28-2020, 02:43 PM
RE: Fedora GNOME3 now available - by linuxfreund - 09-29-2020, 08:21 AM
RE: Fedora GNOME3 now available - by pine76 - 10-04-2020, 11:48 AM
RE: Fedora GNOME3 now available - by rempfer - 10-21-2020, 04:05 PM
  Fedora 37 installation gswatkins 16 6,329 03-16-2024, 03:09 PM
Last Post: michel_luc
  Fedora 36 -> 37 upgrade kills system tydeman 0 483 10-28-2023, 09:53 AM
Last Post: tydeman
  Upgrade Fedora from 37 to 38? acruhl 2 955 07-12-2023, 09:31 PM
Last Post: acruhl
  Fedora Workstation (36) on Pinebook Pro u974615 13 7,551 09-02-2022, 11:24 AM
Last Post: u974615
  No audio on Pinebook Pro with Fedora? foobar 1 1,451 08-22-2022, 12:12 PM
Last Post: snorwood
  OpenSUSE with XFCE/ GNOME3 now available Luke 35 55,056 01-10-2022, 01:06 PM
Last Post: werwolf
  Fedora 33 to 34 upgrade issues tydeman 2 2,534 12-02-2021, 02:43 AM
Last Post: linuxfreund
  setting up fedora from minimal install pine76 0 1,348 11-30-2021, 10:47 AM
Last Post: pine76
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 2,484 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  Some little things to help Fedora users ccunix 0 1,614 05-22-2021, 06:32 AM
Last Post: ccunix
