postmarketOS/Alpine edge image for the Pinebook Pro
#51
(05-25-2020, 04:05 AM)pmjohann Wrote:
(05-23-2020, 02:39 PM)digeratus1. Wrote: I've been running postmarketOS exclusively since the end of March without issues. Well, one of issue - sound - but that was my fault. Are you using the default image from March? Also, had you already performed the trackpad firmware update to your PBP?
Forgot to add that NO I did not perform any firmware updates previously
Not sure if you have Manjaro 20.04 around in an SD card. If you do, their keyboard/trackpad update process is quite nice. Check the thread with instructions here:
https://forum.manjaro.org/t/how-to-flash.../112366/21
Once you update the firmware it shouldn't matter what distro you use, it will work across them all.
RE: postmarketOS/Alpine edge image for the Pinebook Pro - by digeratus1. - 05-26-2020, 02:07 PM
  Debian on Pinebook Pro u974615 7 1,201 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,689 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,198 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,280 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,627 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,298 11-23-2023, 07:37 AM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,416 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,522 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Install deepin OS on pinebook pro wangyukunshan 4 1,627 08-07-2023, 01:12 PM
Last Post: myself600
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 674 07-13-2023, 05:21 PM
Last Post: owaspfap
