Did my Rock64 die?
I try to do X -configure and I get this:
X.Org X Server 1.20.4
X Protocol Version 11, Revision 0
Build Operating System: Linux 4.9.0-8-arm64 aarch64 Debian
Current Operating System: Linux rock64 4.4.190-1233-rockchip-ayufan-gd3f1be0ed310 #1 SMP Wed Aug 28 08:59:34 UTC 2019 aarch64
Kernel command line: earlycon=uart8250,mmio32,0xff130000 swiotlb=1 kpti=0 no_console_suspend=1 usbcore.autosuspend=-1 rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=de:0a:fc:15:fc:d9 eth1addr=de:0a:fc:15:fc:f9 serial=eb80203b044149b cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 root=LABEL=linux-root rootwait rootfstype=ext4
Build Date: 05 March 2019  08:11:12PM
xorg-server 2:1.20.4-1 (https://www.debian.org/support)
Current version of pixman: 0.36.0
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Nov 18 15:50:30 2019
List of video drivers:
modesetting
fbdev
No devices to configure.  Configuration failed.
(EE) Server terminated with error (2). Closing log file.
I think this is because no driver matches my hardware, but I'm not sure what driver I should install.  I was trying the mali-midgard dkms one until I looked it up and this Mali is an Utgard.  Didn't build anyway.
Did my Rock64 die? - by ab1jx - 11-15-2019, 04:16 PM
RE: Did my Rock64 die? - by Rocklobster - 11-16-2019, 10:08 AM
RE: Did my Rock64 die? - by ab1jx - 11-16-2019, 06:52 PM
RE: Did my Rock64 die? - by ab1jx - 11-16-2019, 08:10 PM
RE: Did my Rock64 die? - by Rocklobster - 11-17-2019, 02:59 PM
RE: Did my Rock64 die? - by ab1jx - 11-17-2019, 09:22 PM
RE: Did my Rock64 die? - by ab1jx - 11-18-2019, 10:44 AM
RE: Did my Rock64 die? - by ab1jx - 11-19-2019, 12:58 PM
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 185 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,414 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 367 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 667 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 651 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,689 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 192,722 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 626 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 675 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 34,245 12-07-2022, 08:22 PM
Last Post: luminosity7
